Question about Zenith DVR413 DVD Recorder/VCR
Vcr/dvd burner combo
I have a trutech drt s810. i mad a video on my camcorder and put it in the vcr to copy to dvd. it copied fine and the dvd will play great in the burner that i made it in. but if i try to play it on any other dvd players or even my computer it wont reconize the disk. is there some format i have to do when burning is complete or what is the problem. i have used dvd+r and dvd-r they all will make a copy but will only play in the origianal burner. thanks for any help.
  • breezy7089 Jun 24, 2008
    I'm having the same problem. I burn a disc and it will not play on any other DVD player or computer. What's the point of recording and sharing discs if it won't play in anything but this machine????
  • Jannie Jennings Oct 07, 2013
    How do I get to the DVD menu?
    Problem Solver:
You will have to go into the dvd menu and finalize the disc for it to play on any other player. Check in your manual for more information.
Posted on Jan 06, 2009
Need a download owners manual for TRUTECH CVR/VCR DRT-S810
https://www.2instructions.com/search.php?cmarque=TRUTECH&modele=DRT-S810 Hope that helps.
Jul 26, 2010 | TruTech Televison & Video
Don't know how to copy video to DVD
blank disk to dvd tray....VHS in deck....PUSH PLAY ON VHS...and RECORD on DVD BURNER....if it is a burner...they weren't all burners....it has to say DVD WRITABLE or some thing in that mannern
May 10, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Firmware Update
I have the GoVideo upgrade for the VR 3845 Combo on a disc. Email me at lgspeh@yahoo.com for instructions on how you can get a copy.
LSpeh
Mar 18, 2008 | GoVideo Go Video DVD/VCR Combo
Can't put a VHS in
If the VHS isnt going in it may require a little force as the track might have gotten stuck with dust. if you think its something else i suggest you openj it up and see if these is anything logged in the carriage way or if the tray might just be stuck. once it is open simply insertthe vhs tape and keep pressing in on it until the machine takes it in. while pressing keep you eye on the carriage and see hwat might be stuck as to preven the tape from entering. BUT I THINK IT MIGHT JUST REQUIRE A LITTLE FORCE as it may be binded with lack of use
Jan 04, 2008 | Televison & Video
Trutech DRT-S810 Does not power on
known issue with this unit. The power supply used in this unit is below quality and is often the cause of power not getting to rest of the unit. The company is from china and does not have a usa warranty service since they operate under the daewoo umbrella.
Dec 29, 2007 | Zenith DVR413 DVD Recorder/VCR
TRUTECH/DAEWOO DRT-S810 NO POWER TO PCD RF-IF BOARD
The power supply needs to be changed. Not sure how you could do that since this item is from china and I could not find parts for this unit.
Nov 14, 2007 | Televison & Video
TRUTECH/DAEWOO DVD RECORDER/VCR DRT-S810
Hi!
did you check the +5 volts if exactly? and the +9voltsif exactly? now if you got over voltages in the said voltages you got abnormal power oscillation! or did you check the regulator? maybe the ADJUST Pin is in abnormal function! and try to unload the power board then you can test run the power board by checking the voltages in secondary.
Nov 07, 2007 | Televison & Video
I need a remote
You need to contact "Daewoo/Trutech" directly to get a replacement.  Good luck they are not easy to get a hold of.
Buy a universal remote.  Check the booklet to see if your model is listed before buying it.  This is your easiest way.
Oct 27, 2007 | Televison & Video
MODEL#DRT-S810 DVD RECORDER/VCR COMBO
The DVD recorder is like a PC internal drive. Pull the 4 pin molex connector and check the voltages across 1&3, 2&4. Should have a (+ or -) 5volt, and (+ or -) 12volt (you can compare with a PC's voltage across the same kind of connector if you want). If you don't have a 5 & 12 volt reading your power supply is probably bad. Optionally confirm DVD recorder works by removing and attaching to a (spare?) PC.
Zenith DVR413 DVD Recorder/VCR Logo
277 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
