Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
Free Space problem
My hard drive is showing that I have 326MB of free space, but when I try to save something, it is telling me it is full?
    Problem Solver:
  • 15 Answers
Running at that low of free space is a bad thing to begin with. You didn't specify if it's your primary drive, internal or external, or anythign, but I'm going to assume it's the one with Windows/Operating system on it.
Most modern operating systems need a few hundred megabytes, if not more, as "swap" or "temp" space. When your drive drops down to the levels you seem to be at you can get problems liek that which you mentioned, due to free space allocation for temp files, and whatnot.
Without more detail, like which operating system, type of HD, HD use, type of file you're saving and total space on the HD, I am afraid I can't help more.
For now I suggest deleting some old files, emptying your trash can/recycle bin, or simply restarting (if you don't do that much) to clear the cache.
Posted on Mar 17, 2008
Drive C shows low disc space but is only half full
This could be caused by a virus, or you could simply have a small HDD with a newer version of your OS. Certainly I recommend running a full scan with the free version of Ad-Aware Anti-Virus from Ad Aware Free Antivirus and Antispyware by Lavasoft Protection from... to start with. Also, if you have a smaller hard drive, something around 40GB or less, newer versions of the Windows OS will not consider the percentage of the drive's storage space in use, but only the raw amount of free space available on said drive.
Another possibility involves the paging file and its size, something which would be a concern on any modern OS. If your paging file, or virtual memory allocation, is too large, you can receive warnings about low disk space because even when it is not in use that storage space is counted as "in use" by your OS.
Finally, in general these types of problems can result from not performing routine maintenance on your HDD and its partition(s) and file system(s). Running a file-system integrity scan and a thorough defragmentation operation on your drive is a good idea just on principle alone.
Apr 29, 2014 | Computers & Internet
SAYS HITACHI DRIVE IS FULL
Maybe... you need to free up.... space..? (Sorry, could not resist...)
That is, try to delete files or empty the virtual Trash Bin. If you are certain that there should be enough free space, try a filesystem check. In windows, open the windows explorer (NOT internet-explorer), right-click on the drive-letter, choose properties->tools. There is something like "check for errors". (this depends on version and language of the OS).
I had a program that couldn't cope with too much free space. Almost filling up the drive with some random files made the program work. Ok, this was 20 years ago.
Jan 16, 2014 | Hitachi 750GB External USB 2.0 Hard Drive
R 528 my laptop is problem by c drive in red line today my lape vista window and other drivers by correct with blue
Hi
I think it could be because the hard drive is almost full and not enough free working space on it
because windows needs to have a few GB,s free to use as working space without it it cannot run correctly
could you please go to
start
computer/local disk (c) properties
write down what it says please for
capacity ???GB
used Space ???GB
free Space ???GB
Can you also check to see if you are storing lots of video,s or hundred's of pictures
on the c drive either in your documents or desktop maybe
or have you done lots of backups which could be taking up your space
please check this out for us and come back to us also telling us what operating system you
are running im guessing it could be vista
many thanks
Feb 25, 2011 | Computers & Internet
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
I got this hard drive so I could free space on my laptop. I was able to transfer all my picture files onto it. I checked to see if the files had gone on it okay and they did because the capacity of the...
Just because you transferred it to your external hard drive. You will still have the files on your internal HD. You will need to delete the files off your internal HD and they will still be on your External HD. I had to do this with mine and other clients.
Jan 05, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Why does my laptop show low disc space?
Hello
The low disc space message refers to the amount of free disc space on your c drive. The c drive is the drive on which your windows is installed, thus yu need to delete some games or not neccesary files to free up some space on your drive. Hope this can help you.
Kind regards
Andrea
Nov 13, 2009 | Compaq Presario Notebook
My dvr has no shows, but is 53% full. how do I free up the hidden space?
Are you using TopUp TV or something similar? DVRs save space for these channels. If there is a select channels option you can free space by deselecting the ones you don't want.
Oct 11, 2009 | LG Televison & Video
Ps3
most likely your hard drive is full.
Go to Settings-System settings-System information. it should tell you free space on your hard drive from your total available space.
Your drive is probably filled with demos and saved data from previous games, maybe music or even dowloaded movies.
If still had the same issue after the restore there is a chance that your hard drive was swapped for a very small one. ckeck the system info first:
Free space : 12 GB/37 GB this is for a 40 gb
If that is the problem you need a different hard drive (SERIAL ata 5400 rpm ).. upgrading the hard is easy.. or even go with an external drive.
Sep 02, 2008 | Sony Playstation 3 (PS3) Console
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
88 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
