Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn Air Range SVD48600W (Circa 1998?)
Bought this Jenn Air used 3 months ago. Replaced Relay Board (Which had thermal damage) and the Clock board (which functioned, but no display). Unit functioned fine for 2 months. Now: oven light and interior cooling fan will turn on and off (Sometimes together, sometime separately) at will. Even when oven is set to off. When this occurs there are no fault codes and the downdraft fan switch and light switch do not work. The downdraft fan will come on when a left side stove burner is turned on (as it should). All other functions will work during this time. Cycling power would clear this condition at first, but now has no effect.
  • Anonymous Oct 13, 2008
    chime will not stop. "cancel" will stop it for a few seconds, but then it starts again. new electronic control module 6 months ago. worked ok but fan would sometimes run without stopping. used to be able to unplug and it would reset, but this doesn't work anymore.
  • Alison0428 Jan 05, 2009
    I am having the same problem. My oven is also turning off and cannot always get it to turn back on. The oven light is coming on whenever it pleases and then I cannot get it off. It keeps beeping with an error that says "F-".
  • 552 Answers
Jenn Air Range SVD48600W (Circa 1998?) - ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Posted on Mar 17, 2008
6ya staff
SOURCE:
Jenn-Air oven shuts down after FC and F5 errors
Their was a good possibility that the solder could have been lifting of the contact points on the board, if the symptoms return i would check this, along with the said cleaning method :)
Mar 15, 2014 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air JDS8850BDS control panel malfunction
You need a new control board. I bought similar range in 2004 and I just got my 3rd control board. Heating the oven over 400 degrees and using the self-clean function kills the board.
Aug 11, 2009 | Kitchen Ranges
Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
Mar 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
RELAY BOARD JENNAIR RANGE 1200/693
yes check your warrenty i think that bd is under a five year warrenty so the installer if he is an authourized service tech for jen air or whirlpool should not have charged you for the part and any new part you bought should have came with a full year warrenty call cust relations not cust service at whirlpool as they are not the same branch
Mar 28, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air svd48600w
If your display has gone dimmer and dimmer or just gone out it is probably the display board. There are a few capacitors on the back of the board. There is one that is 68 Microfarad 35 Volts. It is common for this one to go bad. I replace it with a 68 Microfarad 50 Volt rated one and that usually solves the problem.
Mar 03, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Feb 23, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air Gas Range
F1 is a bad power relay board.
F8 is a shorted meat probe alarm (probe jack or the harness to the probe jack)
Dec 19, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
880 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
