Question about Sony Cyber-shot DSC-W50 Digital Camera
Not able to shoot photos
Viewing the pics in the memory is OK
Batteries are OK
But on switching the camera on, it switchs off again with a beep sound
I do not know what is wronge, but I can not use it as a camera, only I can use it to view the already stored photos
When turning on the camera, it tries to open the shutters on the lens 3 times, only partially opening and closing, then says "access, turn power on and off again". It also sounds like it may have something loose inside, as it rattles.
  • 3 more comments
  • cabecinha Mar 24, 2008
    The camera only show access on display and put the lens out and in 3 times and after apear turn off and on again!!! I really don't know what happens??
  • Master11 Mar 26, 2008
    Yes,I have same problem too...
  • Anonymous Apr 25, 2008
  • Anonymous Jan 05, 2009
    Same problem,
  • Shiva753 Jan 05, 2009
    Same problem but able to take pictures but moment we try to zoom the idotic message appears and forced to turn off
Camera dropped from 5 feet and not closing
Posted on Feb 14, 2009
OK, I have this camera and it started doing this to me about a week ago.  I assumed it had reached the end of it's life after many, many excellent photos.  As a last resort when the lens popped out after first switch on (when it's doing the clicking business) I grabbed the lens and wiggled it gently back and forth (as if zooming a conventional SLR).  It appears to have been fixed, remarkably!  I switched off and switched it back on and all seems OK.  (I'm not holding my breath and will probably keep looking for a new one but for the moment it's sorted out.)
Posted on Jan 04, 2009
SOURCE:
I just bought a GE X5 on Dec 11, and while I was trying on the different features and switching between play back & camera modes, it just shut off. Yesterday, I was shooting a video and it hang. I have...
When shooting videos, you should have a class 6 or better card. Slow cards can't keep up with the amount of data and often "hang" or stall. This could be the problem. Does it still shoot photos ok?
Dec 13, 2010 | GE X5 Digital Camera
My memory card is completely empty, all photos
You need to reset the file-numbering.
Turn mode-dial to Set and turn on the camera. Select Frame No. from the setup menu. Switch Frame No. to Renew. Press OK. Format the card (also from the Setup Menu) After formatting, select Frame No. againg and switch to Cont. File numbers will now start from 100.0001 again
May 10, 2010 | Fuji FinePix S7000 Digital Camera
My fuji finepix s5600 has stopped taking pics,just as i put new batteries into it,i can look at previous photos that i took,but it just wont take the pics,why?
Is it showing any message on screen as to why it won't take pictures or is it when you switch over from viewing to taking pics that it shuts off or just won't let you take pics?
Jan 07, 2010 | Cameras
Canon eos 1ds battery life
This is a year old post and I would hope you have an answer by now, if not no harm I guess.
The batteries that first came with Canon's 1 Series cameras where pretty good sort of. Mine is a (NI-MH Battery) and would last about 300 frames with lots of viewing and powering the IS lens. Big thing about these batteries you need to use them up completely before charging if you don't and charge the thing part way through the battery has a memory and you then get less use before having to charge it again. I then bought two more third party batteries which do not have the memory. When on a shoot I load up the Canon battery shoot through it and then switch it out for the "No Name" battery which B.T.W. is 2200mAh and I get about 500 frames, lots of viewing and powering the IS lens. Bonus was to me I got two third party batteries for half the cost of one Canon battery
Nov 15, 2009 | Canon EOS-1Ds Digital Camera
Sanyo VPC-E7 digital camera
Your Probleum is Sometimes occer when camera is put in pocket and press som keys then first on camera they shoot photo.you put to little pushing with the help of hands and then turn up and down you see your camera would worked again.
Nov 09, 2008 | Sanyo VPC-E7 Digital Camera
Memory card error
Zeru
I have a similar problem with one of my older memory cards. I have replaced it with a newer one. I don't have the problem any more. I keep the old card as an extra, knowing that it will only store a few photos.
The comment by the GUEST sounds like a different problem. That problem sounds like the "memory card switch" is locked. This is physical switch on the memory card itself, and will not allow writing to the card.
Dec 19, 2007 | Canon PowerShot A450 Digital Camera
No image
79da3bf.jpgWhile in picture taking mode, press that button. It will restore your viewer.
Nov 20, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Kodak DX4900
try to remove the memory card first and turn it on without memory card, it has a built in memory by the way. if it works, throw away the memory card, If the problem is still there, try to shake it side by side. If it still dont works, it needs to be opened, something is stucked inside.
Aug 26, 2007 | Kodak EasyShare DX4900 Zoom Digital Camera
Shutter will not close. Appears to be locked with shutter out. Slider is ok. Not batteries. Cannot take a photo. Nothing shows up on quick view. Red light blinks for a short time. Makes a beep sound....
it´s normal in that kind of cameras it can be fine but after u shoot one pic with flash will happen the same, to fix the problem u will need to send it to a repair centre, they will isolate some stuff inside to prevent that from happening.
Dec 27, 2006 | Olympus Camedia C-350 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
49 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
