Question about Delfield 26.64 cu. ft. Commercial Freezer Meridian MHPT1GS
Voltage to evaporator fan
This freezer is actually @ 4 cu ft the evaporator fan plug only gets 35 volts.traced as far as terminal board and still same voltage. Wondering if the thermostat is partially open there is some resistance therefore not complete continuity box temp is 75 degrees
  • Delfield Master
  • 1,253 Answers
Lots of things to look at. Let's get started.
Evap fans usually have some sort of fan delay, usually mechanical. These go bad fairly often. This could add resistance to the circuit.
You can have up to 1 Ohm of resistance through most mechanical t'stat devices. Anything over that, replace it. If you are getting 35 volts out of the board, it's probably the board. If you got voltage going in and not coming out, it's usually the board.
Posted on Feb 14, 2009
What should I do? Freezer is not cooling, inside light is on, control panel is off temp shows blinking OF and FF
usually means low freon... (of) and evaporator fan failure. can you hear the fan running in the freezer portion?...
Jun 05, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
GE bottom freezer stopped cooling
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
True freezer T-35F shoudl it be running hard all the time?
Check and clean condenser regularly, check thermostat set at 2 or 3 and check fan is working ok. Apart from that, check the evaporator isn't frozen solid with ice.
Jul 01, 2012 | True 35 cu. ft. / 991 liter Commercial...
My freezer has power, but the fans are not going on when the door shuts and the temperature is rising.
The defrost termination/ fan delay control is a temperature-activated, single pole-double throw switch. ).
The control is wired into the refrigeration circuit. The control is located high on the evaporator where the frost is likely to clear last. The function of this temperature-activated switch is to terminate defrost when the evaporator coil has been defrosted, and to delay the evaporator fans from coming on immediately after defrost.
The coil must reach a temperature of 25* F. for the fan delay to close allowing the fans to operate.bobicehouse_38.jpg
Jul 22, 2011 | True 49 cu. ft. / 1388 liter Commercial...
Compressor runs bypassed thermostat with wire that turns on and off compressor,but freezer cabinet is not cold 65 degrees evaporator fan does not turn on,condensor fan on,sttill no cold
If you have just turned it on it takes awhile for the fans to come on. The evaporator coil has to get cold about (10 to 20 degrees) and make a klixion fan switch to turn the fans ON.... Is the evaporator coils getting a frost pattern on them??? If not then the system may be low of Freon.. If the coil is completely froze up and you are getting frost back to the compressor..... then you have a bad fan switch or a door switch.... If you have a wiring diagram you can trace out the wiring.... It is usually down by the compressor or control panel... hope this helps.
Mar 30, 2011 | True 23 cu. ft. / 651 liter Commercial...
We have a True TS-49F freezer that the interior fan have stopped working. Holding the door switch does not activate them. Unit is out of warranty.
Most all commercial freezers like yours have, what is called, a fan delay. It is located in the evaporator case and is usually attached on or very close to the actual cooling coil. It may also be a combination switch known as a defrost terminator/ fan delay. It's purpose is to keep from circulating warm air. If the cooling coil does not reach a preset temp, the fans do not come one. Another thing is that the fan motor may just be bad. If you have more than one fan, then chances are that it's going to be the fan delay. I would start there to see that either the fan delay switch is bad or there is a reason that the coil is not getting cold enough to activate the switch.
Nov 09, 2010 | True 49 cu. ft. / 1388 liter Commercial...
No evaperater fan run,compressor running,coil is frosting but no voltage to inside fan.
Look to the fan delay/defrost terminator that is located inside to the evap. It is usually attached to the evap coil. check there first.
Aug 25, 2010 | True 206 cu. ft. Freezer TWT-67F
I have a T-49 freezer with compressor running defrost timer board is showing in refrigeration mode. I have power on the #4 terminal going to the evaporator fans. Both door switches are closed. I am not...
most freezers have 2 controls. 1 is a defrost terminator and the other is a fan delay. the delay and the defrost terminator can sometimes be a "2 in 1" type switch. you would have to study the wiring diagram. The delay will not let the fans come on untill the evap reaches a preset temperature. take another look at the diagram. It may be that the evap is not getting cold enough. you may have a refrigeration issue.
May 15, 2017 | True 49 cu. ft. / 1388 liter Commercial...
T-23F FEERZER
fan burnt or relay fauly or fuse blown
Mar 10, 2009 | True 23 cu. ft. / 651 liter Commercial...
Delfield 26.64 cu. ft. Commercial Freezer Meridian MHPT1GS Logo
102 people viewed this question
Top Delfield Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Tom Donaldson
Level 1 Expert
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
