How To Reload Your Operating System
Here is a KB that discusses that error:
- KB16471 BlackBerry Desktop Software prompts that an Internet connection is required to configure synchronization
Hopefully it contains something useful!
As an alternate method, from a PC, you can install any OS package to a BB via this procedure:
Note that while written for "reload" and the Storm, it can be used to upgrade, downgrade, or reload any BB device model -- it all depends on the OS package you download and install to your PC. You can even use a different carriers OS package by simply inserting, between steps 1 and 2, the deletion, on your PC, of a file named VENDOR.XML. Be sure that you remove, from your PC, any other BB device OS packages as having more than one installed to the PC can cause conflicts with this procedure.
If you are on MAC, you are limited to only your carriers sanctioned OS packages...but can still use any levels that they currently sanction. See this procedure:
- KB19915How to perform a clean reload of BlackBerry smartphone application software using BlackBerry Desktop Software
