Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printer paper feeeding out the back of the machine
My computer is not accepting installation of Brother MFC-240C
Posted on Mar 26, 2008
Paper Feeed
fuser roll gear is break replace it
Feb 21, 2013 | Office Equipment & Supplies
XEROX PHASER 8400 SAYS CLEANING SHEET NEEDED. THE MACHINE JAMS EVERY TIME WE TRY TO FEEED IT IN.
There is probably a tiny sheet of paper stuck inside the printer somewhere which is causing the jam. You basically have to find out where the previous jam was and check the rollers to see if they are clear.
If it is cuz the cleaning sheet is too stiff, then you may need to feed it from the manual feed tray.
Oct 13, 2010 | Xerox Phaser 8400 Laser Printer
Brother copier paper feed grabs 2-5 sheets at a
check the feeed rollers ateh seperation roller the one that seperates the pages is worn.. it has proberly worn the tread and if its sn=mooth or worn it wont stop multi feed
Jul 29, 2009 | Office Equipment & Supplies
I was given a laminator but it does not have instruction booklet, how does it work?
the main way they work is that you have the laminate pouch into which you slide your paper then make sure that the pouch is put between the guides closed side first the machine will take a while to warm up after you have plugged it in when the green light is on push the pouch in slowly the motor should turn and feed the pouch in automatically.. the important thing is to make sutre the pouch is correct for the type of machine you have and that when feeeding in the pouch it goes in closed end first otherwise it could open and jam.. Good luck A>>
Jul 27, 2009 | Office Equipment & Supplies
How to find a paper jam and clear it.
I just bought this K8600 printer and it keeps having paper jams. I clear them but it won't feeed the paper through. Any suggestions???
Jul 11, 2009 | HP OfficeJet Pro K8600 Printer
Ribbon take-up spindle does not turn
I initially had the same problem and then found I had to set the paper type to TTR and by doing so the ribbon take-up spindle started turning, the default paper type DT does not make the spindle turn.
Jul 03, 2009 | Intermec EasyCoder PM4i Printer
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Paper jammed, upon removing paper, paper does not
My CX4800 developed the same problem. It was an excellent machine until then. I tried everything I could think of, and finally decided it must be the rather large feed in rollers at the right of the paper bin (one below and one above the paper) that had worn too smooth to pull the paper in. It works fine if I will give the sheet a "push" when it starts to go down
If it doesn't feed any paper at all (even regular sheets) and you already have tried loading just 1 sheet it still doesn't feed it...means that it is an issue with the hardware itself particularly the paper sensor. This is usally caused a paper jam and clearing out the jam in the incorrect manner. If your printer is still within the 1-year warranty from the date of purchase, I recommend that you contact Epson technical support for a replacement or service center referral in you area if beyond warranty period. They may also provide you with other options suitable for you needs
You probably have a sticky paper feed sensor or a small bit of paper stuck under or around the sensor. Unfortunately the sensor is really difficult to get too without pulling the machine apart, but can be done if you take your time. The sensor is visible looking into the machine just adjacent to the printhead when it is parked behind the metal support
and if u have any lines on the paper when you print, it is most likely paper fluff or a hair struck under the printhead. Put a small soft cloth on the paper feed platen and run the printhead over it gently. Turn the printer off and then open the cover. Turn the machine on and when the printhead moves off the cleaning station, pull the plug out (this won't hurt the machine). then place the piece of cloth on the platen and slide thge printhead over it. Don't force anything. There will be mild resistance but not much.
If this seems too much, then a service agent might be your best choice but expect to pay around $50-$60 for the job.
May 02, 2009 | Epson Stylus CX4800 All-In-One InkJet...
PIXMA MP780: Multiple pages feed together
Most paper feeding in printers is done via rubber rollers. These rollers get dirty and over time, the dirt glazes on to the roller. When this happens, the roller loses its grip. If you look at the rollers they will actually look shiny. After a while the rubber will dry rot and it becomes a more frequent problem. Try the following:
(EASY/LIGHT CLEANING) Get some inkjet cleaning paper at you local office supply. This is usually a thick absorbent paper that you spray with a cleaner and "print" with the wet page.
(MEDIUM) If that fails, unplug the printer and try using rubbing alcohol or ammonia to rub the rollers with a terry cloth. Be sure to rotate the rollers and get them all the way around.
(HARDER/BE CAREFUL) For hard glazed dirt, you may want to carefully use an hobby knife to scrape it off the rollers, being carful not to damage the rollers. Follow up with alcohol cleaning described above.
Feb 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
24 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
