Question about iLO (2 GB) MP3 Player
My problem Thats not the problem, it doesn't have any protection on it. I didn't just buy it. it was working perfect for like a month and then all of a sudden it wouldn't read anything
  • 8,596 Answers
The Windows Media Player 11 issue is sporadic - it often takes hold after you have updated Windows Media Player with a "Hotfix" - Microsoft has been issuing them at least monthly for the past 6 months with their Windows Updates. So it makes sense that your player was working fine one day and not the next. This is definitely NOT an electrical problem.
Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "iLO 2GB player" (wording may vary slightly), and then select "Format." - this should erase everything, and the player should work normally after reloading the songs.
Posted on Mar 19, 2008
SOURCE:
Samsung galaxy ace plus home key not working
Mine didn't till I found the protective film on th ehome button. Once I peeled that off it was fine!
May 21, 2012 | Cell Phones
I had a mechanic come out and work on my Laredo about 8 months ago; it was leaking fluid from the rear main seal. He didn't fix the leak and since then the gear indicator doesn't match up, and I...
I don't know how you thought he could fix that leak when the trans has to come out? Take it to a transmission shop and stop guessing, and replacing perfectly good parts. Have the trans shop replace the rear seal while the trans is out.
Sep 12, 2011 | Jeep Grand Cherokee Cars & Trucks
Registration key for avast pro
Avast pro isn't required to have great protection. Avast free works just fine. The problem with Avast pro keys is after a month or 2 they pick up on the fact that you didn't really buy the software and they disable your pro service anyway. Sorry I couldn't help more but that's the way it is.
Jul 28, 2011 | Computers & Internet
The original remote didn't work. Guy at best buy said it was probably the remote not the reciever. I bought a logitech harmony remote for my system and that doesn't work either. Where should I...
its the pick up in the receiver , not the remote, you didn't list a make and model, but things like this usually need a shop unless your very qualified to repair it
Jul 23, 2011 | Audio Players & Recorders
CS26, couple of months old. Was using one day, stopped to get a drink came back to start and it wouldn't, rope pulled very easily and didn't sound like it was turning the engine. Opened it up and...
i was given one of these trimmers thats almost new but missing a bunch of parts so im seeking one that owner declares as 'junk'. ill buy and pay cash. locked up okay, blown engine ok, just need handle and body parts with aircleaner assly. anyone got one to sell me? seven06 three22 fourthree79. call mark, regards!
Jul 10, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
Dog chewed 1 month old super mario bros dsi xl what can we do or is a total loss? thanks for your help inadvance. paul landis
Well check if it works. If it doesn't the only thing you can do is return if it has a warranty or for next time you buy a game go to gamestop and ask when you buy a game for a disc protection. I think it is only around 2 dollars!
Jul 10, 2011 | Computers & Internet
I have a 2 in 1 VHS/DVD player. It is a GO VIDEO DV1130. When I press the eject button, nothing happens. The tray doesn't budge. I currently have a DVD in the machine as we speak. The DVD itself works...
Sounds like you've got a problem with either the Drive Motor, Drive Controller or Drive Belt.
It could be an easy fix but it depends on the where the fault is.
Does it make any noise or effort to open the tray?
If yes then its the Drive Belt thats either slipping or broken.
If you remove the top cover and then the cover off the DVD you'll see the drive belt at the front. If it's still in one piece then you can just remove it and get one a few mm smaller.
May 14, 2011 | GoVideo DV1130 DVD Player/VCR
I no longer have any Red color. Only yellow and blue. I've fixed a problem with a fuse on the deflection board. That fuse kept blowing so I re-soldered the FBT and it worked for several months. Now...
The most likliest cause would be a issue with the RED CRT drive board around 35.00 from www.tvrepairworld.com it could also be an issue with the RED CRT itself but thats doubtful as usually the set will shut down if the CRT itself has an issue.
May 09, 2011 | RCA HD52W66 Projection Television
Can't migrate pokemon
thats because you have to migrate it to diamond or pearl then trade it to platinum
Mar 11, 2010 | Nintendo DS Lite
Blows the 15 amp fuse
if you live in a town that has a remote starter installation shop you can just go there and buy a new pinswitch for around 6 dollars i recomend changing the location of it under the hood
and if your red power wire has only 15 amps of protection you should switch it for a 30 amp fuse thats the minimum that is going to be pulled when the unit cranks the starter wire so the 15 will deffinately melt or blow and check to insure the ground is perfectly connected (in the world of current vs. resistance the weakest point will give in first...
Dec 20, 2008 | Bulldog Remote Starter & T-Harness Kit for...
iLO (2 GB) MP3 Player Logo
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
