Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Amana Bottom Freezer control knob
Our Amana bottom freezer does not have the control knob to adjust the temperature. Does anyone know which way to turn the "post" to make it warmer or colder??? oN THIS REFRIGERATOR THE TEMPERATURE CONTROL FOR THE REFRIG IS IN THE REFRIGERATOR SECTION AND THE FREEZER CONTROL IS IN THE FREEZER, ALMOST OUT OF SIGHT.
  • Anonymous Mar 18, 2014
    How to make adjustments to the thermostat sited inside refrigerator below freezer box which is non adjustable can this be done.
  • 552 Answers
Http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Posted on Mar 17, 2008
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
Mar 09, 2015 | Amana Refrigerators
The bottom crisper drawer area freezes and anything along the back of the fridge. I have taken the drawer out to help increase air flow that doesn't work. I have also tried adjusting the temperature i
is the fridge going into defrost mode or is freezer building up with ice? may also want to check the cold control thermostat knob and the defrost timer and also check door seals
Feb 14, 2015 | Amana Refrigerators
How do I replace my freezer light
An owners manual I found online says:
Freezer
  1. Pinch rear tabs on light cover and pull straight down.
  2. Remove light bulb.
  3. Replace bulb with appliance bulb no greater than 40 watts.
  4. Insert front tabs of light cover into freezer liner and snap rear portion over light assembly until rear tabs engage.
The manual illustrates the bulb is behind a plastic grille right by the temperature control knob.
Aug 05, 2014 | Amana ARB1917CSR Bottom Freezer...
Caravell CATF61 can not find temperature control
It's supposed to go to -20! Is there a panel in the side at the bottom? Stat is inside the panel
Mar 31, 2014 | Caravell Freezers
Fridge is warm
Adjust the cooling knob inside the fridge according to the outside temperature.
Oct 27, 2012 | Amana ABB1927DE Bottom Freezer...
Freezer is working well but the refrigerator is not cooling. It doesn't appear there is air coming out of the vent. Is the only vent for the refrigerator the one next to the temperature dial? Are there...
sounds like the coil is iced up maybe any signs of water dripping in refrigerator. if not turn freezer knob down to low and turn freezer knob up to high and try this. and a rating would help. thanks.
Apr 14, 2011 | Amana ABB1927DE Bottom Freezer...
I have an Amana ARB2217C bottom freezer with working lights, fan, and freezer. But the refrigerator doesn't seem to want to cool. I think it stopped a couple of days ago.I've turned the thermostat from...
The problem has to be in the damper control inside the refrigerator section.
Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob.
Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
Feb 19, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
Amana model AB1924DEW freezer is too cold, but refrigerator is not cold enough. Have adjusted controls with no effect
There is a door that allows the air from the freezer to cool the fridge side. Sometimes these are manual or mechanical. It may need stuck or repair depending on what you have. If you look in the back or or fridge at the top there is probably a opening for that air to go through. Maybe it is plugged from ice, you may have to look around if the freezer is on the bottom. It could be numerous problem. Rule out the most obvious first and go from there.
Aug 23, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
379 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
