Question about Lexmark Color JetPrinter Z23 InkJet
Printer moves ink cartridge to left side and won't print
I have tried restarting computer, reinstalling printer, checked all connections and nothing works. Every time I try to print, it acts like it's going to print, but then it makes a weird noise and slams the cartridge to the far left side and then stops. The lights blink and the message is something like 'cannot complete print task'. I don't know. I unplugged the darn thing last week. Too frustrating to keep trying. Any suggestions? One guy said to turn upside down and shake? Also to clean all parts with alcohol. It was working fine and I use it a lot, then all of a sudden...blinking and slamming. Help!!
  • Pnator Apr 01, 2008
    I couldn't get it working, so I just bought another model on ebay. Good luck to you!
Ganjas be da salution to dis revalution to protect hour constitution.
Posted on Apr 15, 2008
My printer not work what im doo
Posted on Apr 01, 2008
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 276 Answers
SOURCE: tries to print, but then ink cartridge moves to left and it all stops
the printer gears assembly is brokem or gor cracked so it is giving this message that ---cannot complrte print task--- just get that assembly replaced to make it proper. it will cost u near $20 for the assembly.
Posted on Nov 20, 2008
We have just put a new black ink cartridge in our printer and now it won't print. The computer says it is error# 5200 and to see the user guide. The manuals don;t have any info to help. I have tried...
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
It says paper jam but we do not see any paper anywhere
did you switch the machine on and off
one of the paper sensors may be stuck pr damaged
Feb 14, 2011 | HP Officejet Pro 850 InkJet Printer
Changed ink printer error on r320
Power off the printer, check for obstructions. Move the print head to the left side, then again check for obstructions. Make sure the cartridge cover is closed. Try to reinstall your inks, push them down the cartridge holder until they click.
Dec 09, 2010 | Epson Stylus Photo R320 InkJet Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Hardware Error 0502
Solution:
Sep 20, 2008 | Dell A940 All-In-One InkJet Printer
Tries to print, but then ink cartridge moves to left and it all stops
Mar 18, 2008 | Lexmark Color JetPrinter Z23 InkJet
Cartridge stall
Solution:
Sep 04, 2007 | Dell 924 All-in-One InkJet Printer
Print wont print
Hello, You may check to insure the USB cable at the printer or at the computer is connected properly and didn't come loose by chance. Try disconnecting the USB cable from the computer, wait ten seconds then reconnect. This will let Windows "find" the printer again. Worse case scenario, you could delete the printer through device manager, reboot you computer and Windows will "find" the printer and reinstall the driver automatically on restart. Also check that the ink cartridge(s) is seated properly.
Jul 18, 2007 | HP DeskJet 3650 InkJet Printer
Open Questions:
See all Lexmark Color JetPrinter Z23 InkJet Questions
Lexmark Color JetPrinter Z23 InkJet Logo
143 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
