Question about Lands Phones
One beep activated
My LG ax275pk phone will not make any sound other than a beep. when i try to change the ringer, or play a sound an alert pops up that says "one beep only activated". I've tried everything i can think of to turn off that setting, but nothing works. any suggestions?
Go to Settings > Sound > Volume > Master Volume > It should say "One Beep". Then press the right arrow button and it will change settings. Change it to the Level volume option. You should have your sound back.
Posted on May 01, 2008
My iPhone SE stopped making sound when ringing, it only vibrates. I have checked all settings/side button, all correct.All other alerts-text, etc.-still work with sound alerts. Anyone know how to fix?
One thing to check is the ringer volume - by default you can change the ringer volume using the volume controls on the side of the phone even when the phone is locked - this often means that it can get pressed in your pocket to zero volume, which is very annoying. Try pressing the volume up button from the home screen while not playing any music and see if it goes up. You can set the volume in the settings and even tell the buttons to only change music volume, which is what I do.
Jan 24, 2017 | Apple iPhone Cell Phones
My phone beeps when its on charge
I think four Alert options could be turned on. To turn it off:
1. Press [MENU]
2. Press "1" (Sound)
3. Press "7" (Alerts Sound)
4. Check each option for the active option and turn it off.
Thanks,
Nov 18, 2009 | LG Cell Phones
Can't set LG phone to 1 beep ringer
Follow the steps:-
  1. Go to menu.
  2. There go to settings and from there go to profiles. If there is a seperate icon for profile then enter in it.
  3. There choose a profile option ( like general, silent, meeting etc. )
  4. Enter the option and enter into personalise tab.
  5. There scroll to message alert tone.
  6. Enter in it and then select the one you desire.
  7. Finish.
NOTE:- My instructions will be valid untill you are in the same profile. If you change your profile then to avail message alert beep once the do the above steps again.
THANK YOU if you think I helped you.
Aug 21, 2009 | LG Shine KE970 Cellular Phone
No SMS Alert LG Renoir Please HELP
I was faced the problem before, after i tried the Reset Settings, the problem solve. You can try to go Phone Settings -> Reset Settings.
Aug 08, 2009 | LG KC910 Renoir Cell Phone
Can't Change Message alert tones
open 'profiles'. It will be inside ;menu' or 'settings' option. after selecting profiles, select 'personalize' and chose the new message alert tone from your gallary.... after that activate your profile.. your ringtone has been changed
Jul 11, 2009 | LG Shine CU720 Cellular Phone
On the LG VU CU920, how do you set ringtones as message alerts?
After going through the manual and talking to an AT&T rep, I found that it is not possible to set your own ringtone as a message alert tone. You can only use your own ringtones for calls and ringer ID's. We're stuck with the 10 pre-loaded rings for the message alerts. :(
Jun 02, 2009 | LG Vu CU920 Cellular Phone
My son locked my LG AX275PK and I have no idea what the unlock code is? Do they give you this somewhere as I have never had my phone locked before.
I just had the same problem. I called Altell and they said if you have never set your code, try the last 4 digits of your phone number and it worked. Hope it helps.
Apr 15, 2009 | LG ALLTEL AX275 Cellular Phone
I265 model
Go to your ringers menu, find the beep tone, (belive its ringer 10, while phone is the ringer is highlighted, press menu, then assign ringer as call alert. Hope this is what you're talking about. If you meant that it's not beeping when somebody presses the button to call you without alerting you, then you go to menu, settings, DC/GC options, and set "alert type" to ring. NOT vibrate or silent.
Dec 28, 2008 | Motorola Radio Communications
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
LG Chocolate Ringer problem
Go to tools, phone settings, voice commands, call alert then do not select name repeat, the other 2 selections have a ring.
Mar 28, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Lands Phones Logo
1,126 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
