Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Constant Streaks I have cleaned the glass the proper way, but we are still getting streaks on Every copy. It keeps getting worse everytime, and althought we have had this problem before we Know it's something we don't have to call a repairman about. Any help is grately appreciated.
    Sniper:
  • 57 Answers
If the streaks only happen when using the document feeder, cleaning the thin glass strip on the left of the machine will help.
Posted on Jun 12, 2008
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Kyocera Mita 2050 there are streaks of toner appearing on the pages printed.
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
Nov 15, 2010 | Kyocera Mita KM-2050 Printer
We are getting streaks on scan and faxes but not on items we just use for regular copying. Where do you think the problem lies?
Clean all the glass surface you see. Newer copiers use a small glass strip that the original scans across. All it takes is alittle white out or ink spot on the glass and you get the streaks.
May 16, 2010 | Office Equipment & Supplies
Severe lines appear on copies. The cartridge is
Most likely it's the toner cartridge. Remove the cartridge, turn it over and slide open the cover over the drum. The drum is the colored cylinder running from one side of the cartridge to the other. Do you see what appears to be the same streaks going around the drum? The drum should be completely clean and free of any lines or streaks. If it has lines or streaks then the cartridge is bad.
Only other possibility here would be the scanner glass. Make sure your streaks don't go away when making a copy from the glass. If they do you could have dirt or trash on your scanner glass.
Good Luck and thank you for using Fixya.
Mar 11, 2010 | Dell 1600n All-In-One Laser Printer
After a few copies are made, black streaks start showing up on the copies and gets worse with each successive copy
for most copier those black streaks are caused by poor cleaning of the Photo Conductor Drum these can be fix by replacing the cleaning blade. after replacing them clean the Photo Conductor Unit and make some test copies.
Feb 27, 2010 | Office Equipment & Supplies
I have started getting streaks on Image Runner 2020
Try to print something, if there is any streaks?If no the problem is in copy glass (dadf or platen glass).
If there is streaks on print also,it could be the drum unit ( pull the drum unit out and see if on drum surface is any black streaks), fixing film is worn out, and in the worst case you have problem with toner unit ( on toner unit you have current leackage ) and you need (in best case) clean the contacts on toner unit, and in more expencive case tochange the toner unit.
Oct 01, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Black streaks on copies. Gestetner 1302 How do I get rid of them
Do the streaks appear when you use the contact glass or just when you use the Automatic feeder?
If both, then you need to replace either the (drum unit) or the fuser roller(s).
If it just happens through the auto feeder, then lift up the "feed-in section" (left side) and clean the narrow scanner glass.
Mar 11, 2009 | Gestetner DSc224 Copier
Black streaks all over copy
Copies come out with one black line
Feb 05, 2009 | Sharp AL 1631 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Cannon ImageRunner 3300 streaking faxes/copies
First, do the streaks only appear on copies and faxes made using the document feeder? If yes, the thin strip of glass just left of the large platen probably has has a speck of dirt on it. The speck shows as a streak when the page scans over it. Clean with window cleaner, Viva towels and elbow grease. If you shine a flashlight on the glass its easier to find the specks.
If the streaks appear and you are not using the feeder tray, then call for service.
Mar 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
80 people viewed this question
old marine
old marine
