Question about Rancilio Silvia Espresso Machine
No Hot Water
My Rancilio Silvia no long pumps boiling water, just cold water. I tried the red reset button but pressing it did nothing. I miss my homemade espresso.
  • 13,434 Answers
Does it still have warranty? Id suggest takeing it to the shop where you bought it for warranty repairs, you might want to call them before.
Posted on Mar 17, 2008
  • Ekse Mar 17, 2008
    Im not sure about it but I supose its working on the same voltage that comes out from the socket, So trying to fix it yourself might not be a good idea.
    Guru:
  • 1,894 Answers
Sounds like your Rancilio needs a service, this problem could be caused by the boiler not working correctly, possibly a leak from the boiler or a valve malfunction causing a drop in pressure.
SOURCE:
How do you reset the thermostats on the rancilio?
Safety thermostat for rancilio silvia is on the boiler and has a red button on top.Press this button down and you should be ok.
Other thermostats cannot be reset - just replaced.
If the boiler temperature exceeds 165 degrees Celsius, this thermostat will trip, cutting power off from the element. This is done to try to prevent element damage due to overheating.
Mar 25, 2014 | Rancilio Silvia Espresso Machine
The rancilio coffee machine failed to heat up no steam or hot water but all switch lights work and water pumps through
Remove the top panel, and check the thermostats on the boiler there are 3 of them. One needs to be reset.
Aug 09, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia not heating
Unplug machine and remove the top panel, check the thermostats on of them tripped reset and you should be back in business.
May 29, 2010 | Rancilio Silvia Espresso Machine
Not heating water
Yes, unplug from circuit and remove the top screws, then press all the red buttons on the thermostats, one of them has tripped, you will hear the click when you find the right one.
Mar 05, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Hi - I have a new Rancilio that I just opened today. Steam is coming but not enough water for a brew
maybe is just air in pump,try prime water on steam wand.open steam valve and press button for make espresso,keep couple seconds
Jul 07, 2009 | Rancilio Silvia Espresso Machine
Rancilio miss silvia dispenses cold water
If there is steam in the machine, the only other problem would be if the portafilter was cold and you are brewing into metal or glass demitasse that has not been heated.
Jan 12, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
187 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Ekse
Marvin
Marvin
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
