SAMSUNG TV LT-P2045U that I can not turn on...any suggestions?
The SamSung TV LT-P2045U will not turn on...do you have any suggestions and approx how much it might cost to have it repaired? Of all the things that can go wrong with a TV, turning it on seems like the last thing that should go wrong. I am not happy with SamSung. Any thing that you can suggest would be appreciated. Thanks,
Joy
  • mwatayamvwo Oct 06, 2008
    I have the same problem. The monitor is on for about 3 seconds while the orange power light flashes. Then the picture disappears but the sound is still on. Usually I have to wait about 2-3 hrs before it works normally again.
IB4G2008
  • 3587 Answers
SOURCE: Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
Posted on May 07, 2008
  • 44 Answers
SOURCE: Receiver completely frozen
I assume you have already tried repowering from the mains.
Remove popwer for a minute then plug in whilst holding down the "backup" button - this will reload the software.
Posted on Apr 28, 2009
SOURCE: samsung LNS4041D will not turn on
My Samsung LN-S4041d starting clicking and within two days would not turn on. I found an article online concerning the same problem with leaking capaictors. I pulled out the motherboard and my capacitors cm812,cm811,cm817, cm806 were leaking and/or bulged. I went to radio shack and purchased 4 1000uf 35v replacements. It took about 45 minutes to install, which I had never done before, and the TV works perfectly. It cost me $1.59 for each capacitor, $9 for a soldering iron, and $4 for rosin-core solder. Hope this helps your situation.
Posted on Jun 02, 2009
  • 7 Answers
SOURCE: Samsung LNR408DX/XAA Wont power up
I had the same problem with a 52" Samsung LCD. I found 2 electrolytic caps with bulging tops on the power supply board. (see pic). I looked to be the 5v section but I'm not sure. I got replacement at Fry's for $1.90 each. All is well!
Ahwatukee Al
Posted on Jul 21, 2009
SOURCE: Norcent LT-3222 32" LCD HDTV SCREEN TURNS GREEN
I have the same problem and need help. Have this TV over 5 years and don't know what to do this it
Posted on Aug 30, 2009
I have a samsung s3 gt-i9300 i cant make or get
Your Samsung Galaxy S3 must be restricted to some specific network. That is why it allows only emergency calls when a SIM card from some other network is inserted in. You need to unlock your Samsung Galaxy S3 to make it work with all SIM cards. You can unlock your Samsung Galaxy S3 safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy S3 from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S3 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S3 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S3 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S3.
3 - Compose : #0111*CODE#.
SOURCE: MobileUnlockGuide.com
Oct 02, 2014 | Cell Phones
Change time in ER-650 samsung
It is option 4 in programming mode. Page 224 in the manual
Apr 06, 2014 | Samsung SAM4s ER-650 Cash Register
Samsung c120 unlock code
Hi, you can get the unlock code for a Samsung C120 from www.unlock-zone.com/samsung-c120/rs16wp9/ at low cost
UNLOCKING STEPS FOR A SAMSUNG C120:
Method 1:
1 - Switch ON your Samsung C120 with a NOT ACCEPTED SIM Card.
2 - Samsung C120 will ask for "Password".
OR (if the Samsung C120 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung C120.
Oct 18, 2012 | Pantech C120 Cellular Phone
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
I have a Samsung LCD tv approx 4 year old. When u come to switch it on the standby light flashes and makes a click as though it is switching on then it'll click again and switch off. It will go through...
There is a problem with the power supply, which may be due to bad electrolytic capacitors. Alternatively, there may be a bad relay in the power supply.
Feb 22, 2011 | Samsung Televison & Video
Turns on and off on its own. Can't turn on or off
It is a common problem on this model, the TV on and off cycles, and hear the turn on sound repeat every minute. you can replace the main, the part # you can see a sticker on the board, the format is like BN99-99999C. cost approx $120.
May 10, 2010 | Samsung LN40A550 LCD TV
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung 56in big screen lights flashing-cuts off
theres defective caps in the power supply
Apr 25, 2010 | Samsung Televison & Video
Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
May 11, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
