Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Mitsubishi WS55513 ---Flashing Green LEDs...and now NO POWER.. Hi...got the entire board / chassis out of the TV shell. Going to start checking individual components, starting with the mail power supply PCB and then ? Any pointers? Let me know if you can give some tips before I get out the solder iron (LOL) thanks in advance, -Richard (MetalDad)
  • 2 more comments
  • Anonymous Aug 22, 2008
    Hello, Had the same problem with the blinking green light. Read many articles and web postings concerning the problem. I pulled the DM module / board and removed the board from the metal casing and sure enough there were (4) bulging capacitors as I had read. I could only find 1000uf/35volt/85 degree C capacitors. I used those and TV started and works great. I will pick-up the 105 degree C capacitors and keep on hand in the event that they blow again. Whole thing took a few hours including running out to get the capacitors. Thanks to everyone and all of the postings as it help me narrow the problem and solve on my own without huge cost. Also, I could not get a TV repair shop toeven discuss the issue.
  • JLA857 Sep 02, 2008
    anyone know where the module is and how to remove it. Sorry consider me a dumb blonde that doesn't want to spend 1000.00 to repair the TV
  • marctarver Dec 15, 2008
    green power led flashing. tv won,t turn on
  • moles6969 Dec 17, 2008
    I have the same problem. These capictors that you are talking about is that the same as a fuse that you would find in other televisions.
    Genius:
  • 1,694 Answers
    Problem Solver:
  • 5 Answers
Start by pulling the DM board (looking from the back it is standing upright on the left side in a metal chassis) and you'll probably find 4 bad capacitors (bulging on the tops is a good indication, If i remember correctly they are near the top right corner)
you can buy replacements here..
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P13119-ND
Fixed mine this way several months ago..still working like new.
Good luck
Posted on Apr 03, 2008
Blinking green light of death on Mit WS55513. Changed the four 1000uf (35) capacitors on the DM board and it still won't work. Nothing has changed. Any help? Thankyou, sundayman1@msn.com
THEY are green and look like 1/2 watt resistor but will have amperage marked on them and the board--there at least 2 of them near the caps--if you need a photo of what they look like etower.766@netzero.net---Convergence chips will not cause the set to not boot up (the green light blinks and does not stop)
I do this here for free so if this information was helpful give me a vote here--good luck---if you cannot fix the receiver the only choice is to contact PTS electronics--you can ship it to them for repair/rebuild---part no longer is available from MITSUBISHI.
REGARDS, SD TECH
Sep 13, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS 55513...
sounds like the power supply board is unhappy
Mar 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Continuous green flashing light
ther are some bad capacitors on the dm board in this tv, but this model is not layman friendly, we usually send in the entire chassis to Mitsubishi for a rebuild this cost about $300 then there is the cost of service also, this job will probably cost around $5 or 600 dollars.
Jul 31, 2009 | Televison & Video
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light
You don't even have to replace the whole board. The problem is 4 capacitors (# depends on the model of the TV). Can be fixed for under $10, and a couple of hours of labor.
Aug 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 07, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WS55513
Hello I have a wd-52825 mitsubishi 2004.. it was working fine until last week.. I did replace the lamp and now I have new problems . green light came on, then a sound like weeeeeeeeeeeeeee for maybe 2minutes . here we go .. green light go off..
Help please
Mar 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD 52525 52" 2 1/2 yrs Problem with EPROM
the flashing is a code can you tell me how many times it flashes?
Dec 18, 2007 | Mitsubishi WD-52525 52" Rear Projection...
I had the same problem with a WS 55813,2004 model.Paid 130.00 for local Mitsubishi authorized dealer that told me I needed a new DM module at an additional 505.00. Called Sears and they repaired the board for 146.00 by replacing four capasitors on the board. The tech said there is an exolaination on the web that explaines how to do this. He said this is a very common problem and carries 8 caps with him.He even had to do this to his own tv. The caps are worth 8.00 total.
Oct 11, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
