Question about Motorola Mobility Moto Q
Motorola Q screen cuts out to a black screen randomly
My Motorola Q screen cuts in and out to a black screen for no reason. Sometimes when a call comes in, it takes 5 minutes for the screen to even go from black to anything else. Does anyone else have this problem?
  • 4 more comments
  • mr_flannery Mar 18, 2008
    I've had my Q go black several times just in the first 2 weeks of ownership. Alltel has not given me a permanent fix as of yet, and the only thing that seems to work is to remove the battery and reset the phone (and this is just temporary). I really like most of the phones features, but reliability has been the most frustrating issue.
  • Adam Harris Apr 07, 2008
    I have had the same issue with my Q. My screen will go dark and then not come back. I know the backlight can't be on all the time, b/c it will kill battery life, but I can't see anything. I tried to reset, but taking battery out and re-initiating, but to no avail.
  • GwapeJilly Apr 11, 2008
    Yeah....still goes to black. If I push on the left side of the actual screen, it comes back.
  • Anonymous Aug 27, 2008
    My screen does it too. I push on the top right and kinda bend the phone to make it come back on. I think it might be a loose wire somewhere.
  • z71_rules Nov 30, 2008
    The phone just turns on with a white screen and you can hear the power up song but nothing appears. It used to allow you to call and perform normal functions but with a white screen, now it just shows a white screen and will not allow you to turn it off or use any other functions.
    I've done the hard reset and it used to work, now it doesn't. I'm not sure if there is a loose connection or not.
  • Anonymous May 18, 2009
    Have same problem. A tap to the top right usually restores the display.....albeit temporarily.
  • 3 Answers
OK> I have a Q9h with this problem, took it to the shop, they said its a common problem with the Q9h, something to do with a mainboard flaw. He said it cant be fixed.
Now I say it can. What you need is the screwdriver to open the back (T4 or T5, not sure exactly) and some paper.Now, open the back of the phone, pull off the casing, and you should have an open mainboard. Now, take a strip of paper, fold it up, and slip it in under the sim card slot (there is a small gap between the main mainboard and the piece where the sim card is read. Make sure the paper is snug, not tight, or you may have trouble closing the casing. Snap the casing back in, tighten the screws well, and you should be laughing. I've been good for a week, and saved myself $100 on a new mainboard or buying a new phone.
Posted on Oct 01, 2009
    Problem Solver:
  • 13 Answers
Try this, see if this fixes your issue. If it does turn off Predictive texting, I believe located in the same menu.
Settings > Text Input Settings > Menu > Clear Input History
Posted on Apr 11, 2008
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
My screen will not display anyting. it is black
if incoming & outgoing is ok then change the disply.
if no incoming or outgoing then go for flashing
Jan 27, 2010 | Motorola Mobility V950 Cell Phone
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
Vizio 42" LCD - Random appearance of small black rectangles
There is a processing fault that is starting to occure. What you are seeing is a type of aliasing. This can be in the main signal processing or in one of the control areas.
The set will require service. The service rep will test the set by using board substitution. There are typicaly a number of areas in the TV set that can cause this type of fault. Once the defective board is located the fault will be easy to service with a simple board swap and some adjustments.
If the set is out of warranty, it may be expensive to service. With many of the no-name brands, spare parts can be difficult or impossible to have.
Jerry G.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
I would check and see if you have the text option on under your closed captioning. With the new digital transition the signal for text captioning has been getting messed up during broadcast here lately. If it is on i would just shut it off or go to regular closed captioning.
Nov 02, 2008 | Vizio GV42L 42 in. LCD Television
try tking out the sim card and battery and restart it if tht dosent work try taking them out again and restet or keep them in and reset
Apr 11, 2008 | Motorola Mobility RAZR V3
Black Squares on the Screen
this kind of problem is normally do of bad cable box or sat
Apr 05, 2008 | Vizio L32 32 in. LCD HDTV
Motorola V195 screen randomly broken?
Sounds like a flex cable problem. The flex cable connects the upper half of the phone to the lower half. If the phone still has Motorola Warranty - send it to Motorola, otherwise look for a reputable repair shop. It might be expensive if they have to replace.
Jul 31, 2007 | Motorola Mobility V195 Cellular Phone
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
1,959 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
