External Hard Drive not accessible
I have an 80 GB Hitachi 80 GB external USB drive. It was working fine lastnight. Now when i plug the usb into my computer, the red light on the drive comes on. But I don't here the disk spinning, and it is not showing up on my computer. I cannot access it!!
What do i do?
  • 871 Answers
Open your external drive and check for connections. the hd might be loose.
Posted on Mar 17, 2008
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
My hard drive is not being recognize
Jan 06, 2013 | Computers & Internet
I have an 80 gb external Hitachi Hard Drive. it was working fine. I plugged it in yesterday and I can hear the signal that it is being recognized, but it does not appear in the My Computer section like...
did you use the same leads to check it on another computer
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver:
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 20, 2011 | Hitachi hts548080m9at00 80 GB Hard Drive
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
What kind of enclosure and cable do I need to make my drive exter
This drive is an IDE/ATA hard drive.
To use this as an external hard drive, I suggest you purchase an USB hard drive adapter case (with an USB cable) and install the hard drive into this case.
When you plug this adapter into the USB port of a computer, the computer will see this as an external hard drive.
Mar 22, 2010 | Fujitsu MHV2080AT (MHV2080AT50PK) 80 GB...
Hitachi 80 GB. USB HDD problam.
If you plug it in and it does not appear, it may be choosing the wrong drive letter.
If that drive letter is already in use it will not appear.
Open the start menu, right click on my computer, then choose manage.
Select (on the left) Disk Management.
If it appears in there.
Find the thumbdrive in the list and right-click and choose 'Assign a new drive letter' . Make it like M or somthing far down in the alphabet.
If that does not appear under the disk management then the disk might be physically damaged.
An urban myth (which does sometimes work) includes putting the drive in the freezer for a day or so.
Also remember it might be somthing as simple as a bad cable or port on the computer. Try to access it with a new cable from a diffrent computer.
Apr 23, 2009 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Access
It sounds like you may have a problem with either your USB port or the cable that you are using.
Try plugging in another device into the USB port.  If that works without constant pressure, try using a different USB cable for your drive.
Nov 09, 2007 | SimpleTech Pininfarina 80GB External USB...
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
