I have a problem with my Marantz CD5400 that started a few weeks after the warranty ran out. Basically I can hear the laser or other onternal workings trying to read CD`s but it is rarely able to achieve this. Ocasionally it will display the number of tracks and total time of the CD but press play and the screen goes blank, then display "No Disc". Even rarer than this it will do the above and then start to play a few tracks from a CD, however y track 4 or 5, or if you try to select a specific track "No Disc" appears again. Any ideas? I`d love to get it working because the ound is superb.
  • arthur1969 Mar 17, 2008
    I bought it just under 2&1/2 years ago.
    Master:
  • 788 Answers
It is probably the transport, the CD5400 uses the VAM1201 which should be pretty easy to find on the Internet and replace.
Posted on Mar 17, 2008
  • Dean Joly
    Dean Joly Mar 17, 2008
    Also could be a grounding or power problem with your wall outlet or power bar. Try with a different power bar and/or a different circuit in your house.
  • 552 Answers
Link
the link above will get you to marantz find answers page.
Let me know if you found answers.
Thanks
  • Hjalmer Lamminen
    Hjalmer Lamminen Mar 17, 2008
    If the link does not work go thehttp://www.marantz.com then go to the answers page.
    Guru:
  • 1,894 Answers
How old is it?
Hi _ I have a Marantz CD player a littl;e over 6 years old. Performed perfectly until today, when it started inserting brief gaps in the music, approx 1-2 seconds; at the same time the track / time...
laser cleaning cd's very rarely work. the only thing they are good for is if there is a build-up of dust on the lens. Sounds like you most likely need to have the laser replaced.
Feb 11, 2014 | Marantz CD5001 CD Player
GE Profile PTS25LBMARWW - Power, but no Cold
yes the mother board is located under the plate in the back.. but when you replaced the relay did you put on a 3in1 relay or a manufactured relay?
Aug 01, 2008 | GE Profile PFS22 33" Artica French Door...
Marantz CD5003 CD Player pauses
Not may be! It is. Check and replace it.
Aug 10, 2012 | Marantz CD5003 CD Player
I have a MARANTZ ARCH and it has just started to develop problems with the cd draw it opens and closes fast a few times then will open and close normal also the flap will fold down draw will come out the...
If the system is less than 3 years you still qualify for manufacture warranty, usually it is accumulated dust, you can open the system's case and clean with a dust cleaner can, you can buy at staples, best buy, radioshack, and any major store.
If dust is not the problem than is an electronic problem, there is one electronic component that is in charge of closing the flap at xx speed. If that one is burnt out you can replace it, I recommend you have an electrician look at the circuit. or Contact the Marantz for warranty at: http://us.marantz.com/us/Support/Pages/ServiceCenter.aspx
May 24, 2011 | Marantz Arch 1.0 Shelf System
Hello, i started up my 60gb playstation last night and it ran fora few minutes then turned itself off. Turned it back on and it would stay on for a few seconds and turn off,repeatedly. Did it this morning...
If its an unwanted christmas present, I'm guessing its still under warranty, so call sony. They'll fix it for free. Your problem sounds a bit...irregular.
Mar 25, 2011 | Sony Playstation 3 (PS3) Console
Hi, i have a marantz pm720 amp, when i switch it on, straight away it starts to make loud cracks through the speakers like spikes,then it will cut sound all together for a few seconds then back on, when i...
Hi Paul;
There are one or more transistors failed in the output circuit
I would have tech look at the amp and see what the power supply is doing without spkrs connected
Aug 20, 2010 | Marantz PM7200 2-Channel Amplifier
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
Laser is malfunctioning on my Marantz CD Recordable DR6000
the laser in your DR-6000 is exactly the same as what's in the philips cdr-775 and cd-r-770.
a brand new laser for these are very hard to get hold of and are very expensive. personally i would look out for the above philips models on ebay for less money then take the whole mechanism out and unscrew the servo board and then fit the marantz servo board in place of it and fit it back into your recorder.
i have done this on numerous occasions with no problems.
hope this helps.
Feb 26, 2009 | Marantz DR-6000 CD Player
My marantz cd5400 keep pausing itself during playback
You need a new laser. Cleaning the lens could possibly help maybeee. But it most likely needs a new laser now. Good Luck.
barneyluc
Oct 03, 2008 | Marantz Audio Players & Recorders
107 people viewed this question
 Grubhead
Grubhead
