Question about Lexmark Z1300 InkJet Photo Printer
Not printing colored
Brandnew black and white and color catridges installed but getting only black and white . no color what do I do?
    Problem Solver:
  • 6 Answers
Try removing the color cartridge and reseating it. If that doesn't work, wipe the electrical contacts on the cartridge and inside the printer (cartridge holder) with a clean soft colth. If that doesn't work, I don't have another solution. I wouldn't try buying a new cartridge, I tried that with a cheap HP and got the same result. Personnally, I think of these cheap (inexpensive) printers as disposable--I use them until I encounter a problem the throw them away and get another. I mean, the printer costs less than ink cartridges for medium quality printers that have a slightly lower failure rate. If you want a printer that will last, you're going to have to spend more. The $100 Canons are highly ranked by Consumer Reports. My $.02 worth.
Posted on Apr 11, 2008
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Why my color catdrige is empty faster than black
just change your settings to print in only black and white and it will print just fine. there should be a button on the top of your printer that says print black and white or grey scale , its a common problem .,if you see next time it should work good .(its actually making the black color using the colored catridge by mixing the three colors in diffent ratio.)
Mar 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
Hi there, Can I print in Black & White when I ran out one of colour ink catridges??? On Brother website it says that you can. According to their advice the Error message shoud come up on LCD screen...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up you should be able to tell the printer to print in black and white in your page setup or print properties portion when you go to print your page.
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | Brother MFC 6490CW InkJet Printer
How do I print with black ink only so the printer doesn't keep taking color for b & w printing? I am out of color and the printer won't print unless i go out and buy more color cartridges when i only...
When you bring up the print screen, click on the printer properties tab (top right) and on this screen you will find 'use black ink only' and 'print in black and white'
Nov 20, 2009 | HP Office Equipment & Supplies
Cartridge problem
it has to have both color and bw catridges to work properly
Sep 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
How can I print a color picture without using a black catridge?
Black ink is an essential part of the printing process. The black color is only made by the black cartridge, the color cartridge does make "black".
One or more optional photo cartridges may be available, depending on your printer model.
  • Use the photo cartridge with a tri-color cartridge for best-quality color photos and graphics, and sepia or antique photos.
  • Choose a gray photo cartridge to print black and white photos with truer grays and richer blacks.
Nov 21, 2008 | HP DeskJet F380 All-In-One Printer
Color printing
GO TO MAINTANANCE SECTION IN THE MENU TRY TO TAKE SELF TEST PRINT.
IF IT COMES THEN GO TO NEXT STEP AND TRY TO CHECK THE INK LEVEL OF THE CATRIDGES IF THE INK LEVEL IS LOW DO REPLACE WITH THE GENUINE CATRIDGE ITSELF.
Feb 29, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Lexmark Z1300 InkJet Photo Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
