I own a Gateway laptop computer and the power button was accidentally mashed in by my daughter over the weekend.....After trying to mess with it and trying to push it back up to a normal position, the button completely broke off and fell into the hole where it's supposed to be located. I managed to get it out of there, but now my computer will not turn on at all.....Before it broke completely off and although it was all wigley inside, I could push the button and the computer would power up, but after it broke off, I cannot seem to turn the computer on with anything. As you can imagine, there is just an open hole where the power button should be now....Do you have any idea how I could power up the computer other than using the power button? And is it extremely difficult to fix something like this? And what would the costs be?
  • 667 Answers
What mdel is it? Gateway is notorious for problems with their power buttons even after they fix them their selves. Firstly, if it's under warranty or extended warranty through another provider definitely have it repaired. To get it to power up you can try this: Unplug the ac adaptor snd gently turn it over. Slide the lock on the battery to the unlocked position. Then, while holding your hand underneath the battery so it won't drop, slide the release for the battery. Aftery is out, put the battery back in and slide the lock to the locked position. Then plug in the ac adaptor. If it does power up, watch for any changes with the disply i.e. dimmer picture, color changes etc. Unless you've worked on laptops for years I would not attempt it myself. It can be tough to dignose if you don't know what you're doing. As far as repair goes, most places charge anywhere from $50 - $100 to look at it and tell you what's wrong but if you have them fix it that money goes toward the repair cost. Shop around. I found one for $35. At least you know if it's worth fixing. If it's just a dc oower jack and a power button probably around $200. But if it's main board it's big bucks. All depends on the model and the parts. Just like a car. Hope this helped but you need that power button fixed at least. Any other questions just add a comment and I'll be glad to help.
Posted on Mar 17, 2008
    Genius:
  • 1,019 Answers
I,m afraid you can,t power up the computer any other way.
Laptop power buttons, have a make/break connection. Some power several items at the same time. You,ll need to buy a replacement Switch or switch panel, with the pwr switch on it.
If you give me the Laptop Make/Model.
I,ll search for the part for you.
Mike @ compurepair.
Accidentally disabled touchpad
Typically on a Gateway computer there is a series of buttons on the top of the keyboard area, including a touchpad disable button. If that is not lit, press it until it lights up. Hope this helps! If not, check out this forum that might help you. Gateway nv53 touchpad does not works
Nov 08, 2014 | Acer LX.WZ902.004 - Gateway/nv75s23u...
Gateway wont turn on
That would be a good idea scene it wont turn on you can try simple things like taking out the battery and holding the power button for 30 sec and see if it turns on if not take it to a tech.
Oct 02, 2012 | Gateway M-6827 Notebook
I accidentally pressed a button on my keyboard and now my gateway desktop screen is a bluish green tint how do I fix it?
I do not think it was a button pushed on the keyboard. Check monitor connections making sure that they are connected correctly. It may be a video card matter. Power computer down as well and push in the power button 1-2 seconds. Then power back up computer and see if this fixes this. If not check cables and do repairs as needed in a shop if your not that experienced with computers. John
Apr 19, 2012 | Gateway Computers & Internet
My daughter accidentally erased the operating system off my gateway M405 laptop , how do I get it back?
Power up PC and keep pressing F8 till menu comes up, then select repair, if it still does not work properly. Do it again and this time select factory restore. You will lose all your personal files with factory restore.
Apr 03, 2012 | Gateway Computers & Internet
MASH THE BUTTON AND ONLY THE FAN COMES ON AND IT STAYS ON.NO LIGHT COME ON THE COMPUTER,NOTHING WORKS BUT THE FAN
IT LOOKS LIKE YOU MASHED THE CAPS LOCK BUTTON ALSO. I FEEL SORRY FOR YOUR COMPUTER. LOL!
It is a little misleading but frequently a failing power supply will still have enough power to spin the fan and turn on the lights.
A computer store should be able to replace it for you. Considering your "MASHING" approach to to this problem I highly recommend this approach.
However, if you are comfortable with a screw driver you can replace it yourself. The key is making sure the new power supply has all of the same connectors and equal or greater wattage. The more wattage the better, especially if you have added a 2nd hard drive or a powered video card) Google "replace power supply" and you will find all the help you need. I recommend NewEgg.com for finding the correct PS and the best price.
PLEASE VOTE FOR MY SOLUTION IF IT HELPS :)
Oct 27, 2010 | Gateway GT5220 PC Desktop
While downloading a Cd to listen to on my laptop
That places the PC in "Standby". Simply press the power button on your laptop.
Jan 03, 2010 | Gateway M305CRV Notebook
The power button is stuck in OFF position. How do you disassemble the laptop to fix it?
i suggest you do that. this takes time, patience, the right tools, and a perfect memory for where parts come from
Oct 20, 2008 | Gateway 7508GX Notebook
I dont know if my battery is dead the computer wont come on the red light on the front blinks when i mash the on button
try not to mash it.... Try using the charger to charge it....Desktop?? oooooh. Desktops don't have batteries.
Jun 19, 2008 | Gateway Computers & Internet
Gateway 7324 laptop wireless switch
I just spent ages looking on the net for the solution on how to able and disable the wireless on my Gateway NV54 series. I finally gave up only to accidentally touch the wireless light only to find that was the switch. Its a touch switch along with the volume controls and volume mute.
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
146 people viewed this question
Alun Cox
David Payne
David Payne
