LG Washer dryer error dE
WD12126RD 1200RPM. LG Washer/dryer dE when starting up. Manual says door needs closing. Opened and closed to make sure several times. Door is definitely closed. How do I get rid of the error code? Many thanks.
  • 1 more comment
  • vikrampawar Jun 23, 2008
    dE error though the lid is closed in LG washing machine. How to get rid of this?
  • raffiki Aug 16, 2008
    de Error when the spin cycle is about to begin. LG W T7012 EN
  • domah01 May 19, 2009
    I have the same problem, but I cannot figure out how to remove the spring that is securing the gasket in place. Can someone walk me through this?
    Problem Solver:
  • 6 Answers
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Posted on Apr 12, 2009
  • donjumpsuit Apr 12, 2009
    As an update to this, Mine continued to show dE even after my solution.
    The fix is easy. The door has a switch to lock it into place when it is closed. This switch has a circuit board attached and then a wire and plug attached to that. After shaking around for years, this plug had become detached from the circuit board that sits on the door switch.
    To solve take the rubber gasket off the front of the washer (a steel ring with a spring should secure this) Once its off you can access the switch and reach in and try to plug the plug back where it goes. This solved my problem, but if you are unsure or can't find the correct area to plug it in, the door latch is secured with two screws which should allow for the switch to be removed and then you can see what you are trying to do. Just be careful when unscrewing the doorswitch/circuit board, so you don't loose any pieces in the bottom of the dryer.
Thanks for your help, donjumpsuit. I took the switch and cleaned it, while also moving it from side to side and cleaning its spring. I plugged the washing machine, and it started from 1st attempt ! Thanks a lot.
Posted on Aug 01, 2010
    New Friend:
    Problem Solver:
This solved my dE error too. Thanks.
Posted on Dec 30, 2014
  • Daniel Popescu
    Daniel Popescu Dec 30, 2014
My lg front loader I close door push start get clicking noise at door switch and code de door error is it the door switch it fell off truck on to door face.
Error code 'DE' means a problem to lock the door.
Check that the door hook goes properly into the hole.
Check that you didn't put a lot of clothes in and these are pushing the door glass (maybe a test without clothes would be best).
Check that the door closes good and there are no broken pieces from the door.
If the problem insists, probably you need to change the electric door lock. Here is a video for your help. Generally, it is a cheap part. If you cannot do it yourself, you need to call an engineer.
LG Washer Front Load Door Switch Repair DE code
Mar 01, 2017 | LG Washing Machines
What is LG washer code dE?
The dE error code indicates a Door Error. The washer thinks the door is not closed. Have a look at these...
1. There should be a plastic finger on the door that pushes the door switch when the door is closed. Is the plastic finger broken off by chance?
2. The switch itself could be bad.
3. If you overload the washer, this could cause this error code also.
Aug 10, 2014 | LG Washing Machines
How to fix a EHE error code
1. Start the drier normally
2. Before the "EHE" error appears, open the drier door!
3. Because the door was opened during program, "dE" error is shown
4. Close the door and press "start/pause" to continue
5. Program will continue normally; problem fixed!
Apr 30, 2014 | LG WM3431 Front Load Washer / Dryer
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
When i put the waashing machine on it comes up dE can you tell me what it means please
Hi.
Small d and E means door error. Big DE is drain error.
Hi.
To start be sure that it is small dE , like this:
If it is a big D, then it is drain error, like the one below:
Washers have a door lock with micro-switch or a door lock motor, depending on the model.
If there is a door switch, this can be tested either reading Ohms or jumping its contacts. When the switch has three contacts instead of two the third contact is an 'heater' (impedance). With door closed the two (or tree) door switch contacts must show continuity, which means that if you read impedance using a multimeter the impedance will not be Ohm infinity (circuit open).
If there is a door motor and no switch the motor is tested reading Ohms and verifying that they correspond to the value in specifications.
If it is door error check the connector to the switch or the
(usually VIOLET(VL) 2 PIN on LG) connector to the power board. Disconnect power first and read impedance to check if there is contact.
Regards.
Ginko
Aug 08, 2011 | LG Washing Machines
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
Lg washer dryer wd12126rd what does ve symbol flashing mean.
Actually it is UE error.It means UNBALANCE error where either the machine is not LEVEL or wash inside is on one side.
Check.
ALPER
Cyprus
Aug 05, 2010 | LG WD-12126RD Front Load Washer / Dryer
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
Washing Machines Logo
3,824 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
