Question about GE WDSR2080D Top Load Washer
We just installed a new GE washing machine and just tried to wash our first load (a large bedspread). When the machine got to the rinse - spin cycle, it really made such a racket and moved about on the floor that we stopped the machine and put the bedspread in the dryer. We did not receive any instruction manual with the machine. Do you think it is a problem with leveling or what? Can we download an instruction manual that might help us with this problem????? Any advice you can give us would be greatly appreciated.
Remove packing rod on bottom right side just pull out the rod and toss it.
Posted on Mar 17, 2008
  • 5,911 Answers
There's a very good possiblity that the washer may require some leveling, but there's a lso a good possibility that the bed spread may have caused the problem. If the only thing you were washing was the bed spread this can be a difficult weight to distribute EVENLY around the wash tub when the washer goes into the spin cycle. This problem can be common when washing single large items such as bed spread, comforter, sleeping bag, etc. The tub needs to stay balanced in order for the spin cycle to run with no vibration.
To check the level of the machine, it needs to be level front-to-back and side-to-side. Also, the flooring UNDER the washer needs to be substantial enough to support the weight. If the floor flexes, your washer will walk. This can be common in mobile homes and upstairs laundry rooms.
If you need a manual for the washer, try geappliances.com. In the Search window, use the drop down menu and select "Use and Care Manuals". Type in your COMPLETE model number in the adjacent window and you should be able to find what you're looking for. If your owner's manual is not listed, the web site posts a toll free number (1-800-626-2005) that you can call as well.
I hope this helps you.
  • Jeff Rockwell
    Jeff Rockwell Mar 17, 2008
    PS I searched for it and found two manuals listed that can be downloaded for free. Make sure you have the correct last three letters of your model number and Adobe Acrobat reader on your computer.
SOURCE:
I have a GE top load washer Model WJRR417G1WW did not spin out after rinse cycle.. any idea? Jen
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 14, 2011 | GE Washing Machines
When washing a load the machine is not spinning.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 17, 2009 | GE Energy Star WCVH6260F Front Load Washer
Brand new front Load GE washing machine stop at rinse cycle
Check that the Cold water valve faucet is open. Perhaps the earlier vibration problems have caused a wire to come off the water valve connections inside the machine.
Sep 30, 2017 | GE Energy Star WCVH6260F Front Load Washer
Does not advance from wash to rinse to spin
The washer is new and under warranty so I have asked for warranty service.
May 23, 2009 | General Electric WSXH208H Front Load...
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
GE WDSR2080D Top Load Washer Logo
78 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
