Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ge profile fridge bottom freezing up
Hi There. we have changed the fan on the fridge due to it burning out with ice buildup' we also changed the stat as the fridge would not shut off which caused the ice buildup. the problem now is since the tech left it will still not shut off which leads me to believe that the problem was not the stat in the first place . any ideas and how to do the job myself .we have already spent $400.00 on this problem thanks for any help. Jambuttie
  • jambuttie Mar 18, 2008
    just in case you need it model number PDA18LBMRBS
    and Serial Number HD303169V
Found the problem .the compressor is not putting out enough cold to freeze the coils' only half the coils are freezing in the bottom of the fridge. the fan draws it's cold air from these coils and pulls it up to the top of the fridge where it's dispersed into the top half of the fridge' hence the stat never see's that it's cold enough to shut off the switch . in other words if the coils down below were all working a lot more colder air would be pulled up to the top and the stat would then shut off . Solution is to seek a refund from the service tech and buy a new fridge . it's not worth putting a new compressor into this one although it is only 5 years old hope this helps someone who has the same problem
Posted on Mar 19, 2008
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Aug 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Hello I have a GE Profile with Brita refrigerator bottom freezer and it suddenly stopped cooling in the refrigerator portion. The freezer works but very weakly. Ive unplugged it, let it go for one hour,...
The drain is frozen up. The fan what provides the cooling air for the fridge is stuck in the ice. Remove the vegie crisper and pop the bottom under the crisper s out. Also remove the Styrofoam plate. You will see the problem right in front of you. Use a hairdryer to get rid of the ice build up. Good luck
Dec 07, 2010 | GE GDS18LBR Bottom Freezer Refrigerator
What is causing the items in the vegetable bin to freeze and the ice maker is not working,(ice melted in the bin) and the water dispenser is not working and the filter was just replaced a week ago /
Sounds like the source of your refrigerator freezer temperature problem is due to a faulty evaporator fan motor. This fan circulates the air from the freezer to the refrigerator and back to the freezer. When it fails, temps are warm at the top, cold at the bottom, so the ice melts, and the water tank inside the fridge, near the bottom, freezes. I looked up your model #, but it shows no results so i cannot give you a part number.
Also, its possible if you have a control board microcomputer, its bad as well. Some model GE refrigerators the fan burns out part of the computer, necessitating replacing both.
Oct 05, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Freezing and ice build up stopping fan.
hi,
you could buy a spare cover and experiment with it (the one you constantly have to take off) cut it with a hacksaw blade or bend it slightly with a heat gun so the air from the fan moves in a different direction slightly. I sure wouldnt want to be working in GE's design department and have to be responsible for a huge design flaw like this. Usually GE's are trouble free.
jm
May 26, 2010 | GE Profile PDS20SFS Bottom Freezer...
GE Profile TCC18 Refridgerator freezes Up regularly.
I had the same problem. I changed the defrost thermostat and that has solved the problem. Just to make sure the problem is not recurring I drilled a small hole in the back of the plastic drain(behind the fridge) so that I can put a long screw driver inside to determine if there is any ice build up. None so far after 3 weeks.
Feb 28, 2009 | GE GBS22HCP Bottom Freezer Refrigerator
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Freezer icing up
I changed the defrost thermostat and it solved the problem.
Oct 17, 2007 | GE GBS22HCP Bottom Freezer Refrigerator
My freezer is working but my Fridge is warm?
Sounds like a typical air flow (circulation) problem. This can be due to an evaporator fan not working, a frozen up coil not allowing air flow over it (due to failed defrost system, etc.) or even the damper for the fridge section stuck closed not allowing cold air from the freezer in. The first thing is to check the evap. fan to make sure it's running. It's easy to take the rear interior of the freezer section off and check for fan operation, solid ice on the coils, etc. If the coils have a nice white frost pattern all over then that's ok, but if they are frozen solid block where the air can't flow over them it's a defrost timer, defrost t-stat or defrost heat element (not likely) issue. Usually it's the t-stat or timer that goes out. The t-stat is easy to visually check to see if it's epoxy is "popped" out and of course a continuity check to be sure. The defrost timer is just a swap out sort of thing, not much to test there.
Jan 10, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
196 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
