Question about RIM BlackBerry Pearl 8100
No power gone completely dead.......changed batteries but still dead?
  • 5 more comments
  • DashDalton Mar 28, 2008
    error 365, white screen, how do i reset it?
  • cheryl37549 Apr 19, 2008
    the screen flickered then went off wont charge or come on
  • younghiro15 May 12, 2008
    completely dead. changed batteries and still no power
  • wolvesju May 30, 2008
    Hi there
    I have an O2 XDA Exec and it will not take a charge or start up
    Is there anything I can do
    Thanks
    Julian
  • rizalbdg Jun 04, 2008
    how to hard reset nokia 6708 series?...
    please..
    my phone can't switch on, just look NOKIA on the LCD...
  • Anonymous Jun 23, 2008
    completely dead. only "beep" on touch screen
  • znazir Jun 30, 2008
    I have Treo 755 for only 2 month and it crashed on me while turning off after attending a call. I removed the battery and put it back, charged it whole night, nothing worked. All it show ACCESS POWERED. and by pressing any key it does not work. I tried to put battery while power button pressed on the it shows the message to delete or keep all data, I select any option, it goes into same screen ACCESS POWERED. I donot know how to hard set.
    Any suggestions are appreciated.
    Zahid Nazir
    New Friend:
  • 166 Answers
Did you try to hard reset ?
Posted on Mar 20, 2008
The radio has gone completely dead, no power going in. I have checked the plus fuse, changed the lead and used a different electric point but nothing has changed. Any ideas?
Hey there!
It seems the circuit cell has gone dead. Which caused it so 'suddenly' not work any longer. I suggest you get in contact with the customer care for the device and they can change the circuit board. Because if just one circuit is dead, the whole board is dead too.
I wish you all the best and if you need anymore assistance, feel free to reply back and contact me.
Thank you for using FixYa.
I hope that I helped you & that this post helps you at most!
Don't forget to rate! =]
Jan 15, 2011 | Audio Players & Recorders
At start, led is blinking, but after few\seconds everything stops. No start
Remove your battery and connect tomains power and try again to start! If it starts it's most likely your battery has completely gone dead and requires replacement!
Oct 09, 2010 | ASUS S6F Notebook
My phone has completely gone dead says low battery but was in the charger all night. does the battery inside need changing?
No - the battery needs REPLACING. It can no longer hold a charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Uniden Cordless Phone
I am trying to charge my phone right now but it is just a constant red light where it would usually be orange and it is saying 0% charged
did you run the battery completely flat?
my phone if it has gone dead, when plugged in to charge, has a red LED for about 5 minutes where you cannot even turn it on it is that dead. after those minutes pass the phone can then be turned on, and the LED changes color to orange to indicate it is charging and is also powered on.
Jul 12, 2010 | HTC G1
My phone is completly dead and the computer not reading it and the phone dosnt show a charger or anything please help
There should be a problem with the power supply. please take it to the nearest service centre. you battery may have gone dead.
Mar 10, 2010 | Apple iPhone Smartphone
Battery icon?
Probably your battery's gone bad. This happens and often surprises people, when they don't think that they're even using thier battery. The same people say that they always leave the laptop plugged in and that's the problem. Laptop battery's go dead when they aren't allowed to discharge completely(turn off the battery monitoring) once a month or so. To test this theory, see how long it lasts after you unplug it. If it doesn't last long, you need a new battery. If it does and your laptop goes dead after awhile and doesn't turn back on, you need a new power adapter(or your motherboard's power unit's gone bad).
Mar 16, 2009 | Toshiba Satellite 2435-S255 Notebook
IRiver H320 is completely dead
you can change battery and/or upgrade hard drive (if changing hard drive, save the software to pc then copy to new hard drive)
how to replace battery / hard drive
check and follow this link http://www.youtube.com/watch?v=6HOnpHSgMvw
if you dont have tools http://www.ipods99.com/Default.asp?Redirected=Y
Sep 18, 2008 | iRiver T20 MP3 Player
Dead battery or starter?
Take the battery out and have it charged up. reinstall it and you should be allright. Your car has discharged it completely, and it will need a recharge to start. The gauge is only measuring voltage, and not the status of charge.
Aug 06, 2008 | 1994 Oldsmobile Cutlass Supreme
Power supply malfunction?
Remove the battery and try the cord again. Complete with the moving it around. It sounds like you have already diagnosed the loose DC plug adaptor, but the battery could have gone terminal.
Apr 17, 2008 | HP Compaq Presario V2000 Notebook
Phone is completely dead- will not switch on - battery was not flat as recently charged. tried to charge it again but no response
may be there is some problem with battery try putting any of ur frnd s handset compatible battery in to it and just have cross check ...
may be the battery is dead due some indeed things like overcharging or bcoz of heating effect....
may be power on button inside is gone...
or the charging ic is gone....
if problem persists then contact the technician ...
this simple problem he will not charge more than 300 ..
Feb 07, 2008 | Sony Ericsson W200i Cellular Phone
RIM BlackBerry  Pearl  8100 Logo
55 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
