Question about Microwave Ovens
Spacemaker 2.0. Was set to warm coffee. Door opened before time ended. When door shut screen shows "Coffee", but screen does not respond to touch of any instruction. Blower goes on..Fan picture goes on...then reverts back to "Coffee"...so power is on...What to do?
  • Microwave Ovens Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If that doesn't fix it, you may have a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
Microwave does not shut off unless door is open
Is your microwave screen showing time in display screen.if not then it's most probably the relay which got stuck and giving juice to transformer even the control board stop sending signal. Since there are two switches in a loop ,one relay and one is your door switch. So when you open door it breaks circuits and the microwave stops. However , the could be a faulty control board. You can check it by using your DMM and chck voltage across the leads which drives relay. But be careful microwave capacitors have 5000 volts in it. Short them before started to work on the microwave. Thanks Please rate my work
Nov 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave was heating up some coffee I stopped it and opened the door and it went completely dead. Nothing at all works. Should i try and fix or do I need to buy another microwave?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;';;';'
Sep 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Grinder appears to be grinding, but not ground coffee ends up in the basket. Metal door underneath the grinder is closed.
Empty grinder and chek nothing is stucking to the opening plate If not then replace the solenoid that open the shuter from where the coffee go to grinding chamber Thanks Please rate my work
Sep 06, 2011 | Microwave Ovens
We are trying to set up the hamiliton beach brew station 6 cup but do not have the manual. can you walk me threw it please?
Sure Thing :)
1) Open the lid
2) Take out the filter basket.
3) Take out the Coffee Tank and fill it with water to the appropriate mark at the back of it. (Should be a stepped type marker)
4) Pour the water from the Coffee Tank into the Water Reservoir in the coffee maker it's self. (This should be on the left side of the metal warming plate.
5) Place the Coffee Tank back on the brew station.
6) Place the Filter Basket back in the coffee maker
7) Add a coffee Filter and 5 Tablespoons of coffee
8) Close the lid
9) Press the Brew/Start button (The top left one)
Jan 08, 2011 | Hamilton Beach Microwave Ovens
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
GE Microwave, inexpensive model, I place a cup of coffee to warm on the turntable, enter a time, it ends and beeps, I open the door, the coffee cup handle is positioned away. I've gone through many...
Hello BillJohn! I've found that, after many countless hours of precise trial and error testing, that the optimum placement of the cup and a predetermined time entered on the keypad will yield the desired results you're seeking.
By placing the cup on the outer edge of the turntable, with the handle facing to the right side, when looking straight at the cup of water, you would then close the door until it latches and enter in a time of 2:38 onto the timer, (that's 2 minutes and 38 seconds) with a termperature setting of either low or medium, (not the default high).
This will provide you with a warmed up cup of joe, with the handle facing in such a manner that you should be able to grasp it in either your left or right paw without much trouble. However, this will only work approximately 82.5% of the time, the rest of the 17.5% the cup will end up at the 3 or 4 o'clock position (when the handle will be facing the back of the micro).
Otherwise, you'll be destined to have to grasp the cup with your hand and manually rotate it until the handle can be grabbed easily for extraction from the microwave. Of course, it goes without saying that that cup could be quite warm after the timer beeps and signals that the heating/cooking process has been completed.
Please remember that this highly sofisticated kitchen appliance was once only available to the ultra rich, back when the first Amana Radarranges were available for sale. These microwaves once had the unbelievable pricing at around $1200, all so some ultra rich person could reheat their leftover quails eggs and caviar, (along with that peruvian cop of coffee that their butler let go cold).
So be thankful that modern manufacturing technics have been able to harness the atom vibrations that allow for rapid heating and cooking for under $100 these days! Why just today, Home Depot was offering a dal for a small microwave for $19.00 on their Black Friday deals! I would have purchased it, but after seeing your issues with these new fangled devices, I decided that having to rotate my cup after reheating it, was just too much to do, even for the odd 17.5% of the time it happens!
Enjoy that warm cup of Joe and please keep an ongoing log of your actual results of how many times the cup and handle end up in the unaccessible position of 3 and 4 o'clock for the next 30 days.
I'm seeking more real-world data before I publish my statistics on this unusual cup/handle ending position phenomena.
Hope you find this Very Helpful and best regards!
Nov 27, 2009 | GE Microwave Ovens
While cleaning it the vent began to open and close and the microwave would not shut the vent down when the keypad was used to end the cycle. Now it only shows F3 on its screen when we try to set it up...
The "F3" error code means "Shorted key panel (touch pad)". The correction is to replace the key panel aka a membrane switch or a touch pad. The control panel in that case is just a plastic frame.
please rate this help to keep us online
Aug 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Spacemaker 2.0 was set to WARM Coffee. Door was opened before warm finished. After door closed screen shows COFFEE but is unresponsive to touch of any part of screen. Cannot change, end, or...
Let us know if the hard reset doesn't fix it.
Mar 17, 2008 | Microwave Ovens
Spacemaker 2.0 was set to warm coffee. Before warming finished, door was opened. After door was clossed screen remains showing "Coffee" but screen does not respond to any touch.
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
