Question about Sony DCR-HC32E DV Digital Camcorder
Touch Screen on Sony DCR-HC32 Camcorder Does Not Work
Touch Screen on Sony Recorder stopped working suddenly. Nothing happens when you touch the screen. Cannot rewind tape, go forward or go to menu on the screen.
  • 6 more comments
  • David124 Mar 17, 2008
    I had pressed the reset button and hoped that would work. Unfortunately the screen shows "CLOCK SET" and I cannot remove it from the screen. Any other suggestions would be appreciated.
    Is there any technical reasons that would identify why the touch screen does not work? Thank you very much.
  • Anonymous May 04, 2008
    I have the same problem. I got the calibration screen to work but it just does the same thing over and over and then still doesn't work. I also hit the reset button and had the same problem.
  • Anonymous Jul 08, 2008
    I have the same exact problem with my camera. I too pressed the reset button and now have the clock screen up. Can't do ANYTHING, rewind, play, set clock, nothing! Tried the best solution but that didn't work either. Any other suggestions?
  • iamready Aug 08, 2008
    I hadn't used the camera for awhile and when I did the touch screen would not respond. The camera will record but none of the functions are available. I haven't tried any of the solutions yet.
  • Anonymous Sep 02, 2008
    Same thing. Touchscreen won't respond, and after resetting unit it just waits for me to set the date. Hmmm...
  • Anonymous Dec 03, 2008
    ditto over here
  • braddah007 Dec 03, 2008
    ditto over here, however if i turned the screen forward i can access some of the functions, not all as  the calibration is off
  • sanjeyaraj Feb 07, 2009
    I TOO COME ACROSS THE SAME PROBLEM I BELIIEVE OS OF FREQUENT OPENING AND CLOSING THE CONNECTION WOULD HAVE LOST.
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Mar 17, 2008
  • Roy Aaroen Sr
    Roy Aaroen Sr Aug 29, 2010
    Believe it or not, it actually started working again?...from a technical point it makes no sense, besides dust or something. Generally you don't smack electronics...strange it worked,..thanks!!
Ctf100
I encountered the same problem, and recycling the unit in the docking station with the battery removed fixed it for me. Thanks very much.
Posted on Nov 02, 2008
  • sims_7491 Nov 02, 2008
    Sorry. The post on 11/2 was obvious intended as a comment.
  • milk_monkey1
    milk_monkey1 Sep 24, 2012
    I have the same problem and those things aren't working, the screen is on clock set and won"t let me do anything
D touch screen buttons on my Sony Hvr-a1p video camera does not work. I can't rewind, forward or even play video back.
Hello, try to reset the camera, if you need more help to repair your video camera i found a factory service manual for it you can download from the below link:
http://goo.gl/Ji4XI
Good Luck
Apr 19, 2013 | Video Cameras
How to rewind/fast forward trough currently listening segment?
Touch the screen, and 'reverse', 'pause', and 'forward' icons will momentarily appear on the lower portion of the screen. Before the icons vanish, touch either the forward or reverse icon and continue to hold your finger on the icon without lifting it off of the screen. Fast forward or rewind will then begin, at a rate of 5 seconds per second held. I am told after holding for 15 seconds or longer the speed of the fast forward may increase (true for other Coby models I have owned), but so far I have had no luck getting this to occur with my MP828.
Jun 23, 2012 | Coby MP828 layer
My Sony handycam won't allow me to use the touch screen features in play mode. I can't rewind, play or fastforward the tape. It has reached the end of the tape - what now?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Reinsert the tape and check the operation
Try another tape to check whether the issue persists only with particular tape.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: In the above figure, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Dec 18, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
Touch screen doesnt work
The connector which is called "Flexible Board" is cracked which connects touch screen panel with the main board. You need to replace that flexible board and your camera work fine again No worries, just contact any expert who have experience.
Thanks for using fixya.
Jul 10, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
M600i touch screen
Past experience shows you will not satisfactorily resolve this problem until the LCD panel is replaced. Spares are reasonable easy to source, e.g. (ebay.com, item number 280296211660).
Oct 25, 2008 | Sony Ericsson M600i Cellular Phone
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
LCD screen will not respond to touch
First of all examine the LCD connecting flexible strip. If faulty or broken, let me know. Sivaram.V videolabs@gmail.com
Jan 08, 2007 | Sony DCR-HC18E Mini DV Digital Camcorder
All of a sudden some of my tapes will not playback and others will??
I have been experiencing the same problem with my Panasonic PV-GS120. I don't know the root cause or real solution, but I found if I keep playing the tape, rewind->play->rewind->play, eventually I would get the image back normal. I think I would try to clean up header with a header cleaner to see if it helps or not. If not, I plan to submit a request to Panasonic support to check out possible solution. Good luck.
Oct 22, 2006 | Panasonic Palmcorder PV-GS120 Mini DV...
Sony DCR-HC32E DV Digital Camcorder Logo
4,792 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
