TV subtitle setup
I'm in the UK and my neighbour, who is hard of hearing has recently puchased a Technika 19inch LCD TV with a builtin DVD player. Model No LCD19DVDID
As he is hard of hearing, he was hoping the TV could be setup for permenant Subtitles on all chaannels to be displayed.
Can you help?
Help me to set up the menu bar to be on the bottom and not at the middle
Posted on Jul 08, 2009
SOURCE:
How do I unlock Technika DVD player?
Unlock Technika DVD players - DVD Demystifiziert
www.dvddemystifiziert.de/codefree_en/technika.html
Unlock Technika DVD players - DVD hack. Technika DP 301 ... dezoner, dezonner, destravando seu dvd player, leitor de dvd, destravar, desbloquear, regionsfri, ...
Technika LCDDVD19-918 Multi region hack needed ' AVForums
www.avforums.com > ... > Blu-ray & DVD Player Multiregion Hacks
Sep 25, 2014 - Just wandering if there is a multi region hack for the TV/DVD combiTechnika LCDDVD19-918. ... Make sure there is no DVD in player, turn over to DVD on input Technika HDMI DESIGNSS10: Region hack please!
Sep 29, 2014
technika dvdfaw08 region hack
Sep 27, 2014
Technika BRSS10 Bluray Player Hack for DVD & Bluray
Sep 25, 2014
Technika DVDFAW08 Region Code
Dec 14, 2009
More results from www.avforums.com
Nov 26, 2015 | Televison & Video
Technika television
its an error in the power supply board.
Aug 19, 2008 | Televison & Video
CC (closed caption) won't show up on DVD movies for LG 42CS570 hooked up with standard DVD player (not Blu-ray). How can I fix that?
Subtitle setting is in the dvd setting not the tv, If the DVD would have CC it would be on the case, CC is encoded in to the tv signal
Mar 01, 2014 | LG 37LP1D 37 in. LCD Television
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How can i remove unwanted subtitles the movie is in english and the sub titles ate very distracting
Usually, if the subtitles are from your dvd player, you can go to the main menu, select "languages" or "setup" (depending on the dvd), and find the subtitle option. You should be able to shut them off there in the menu. If the subtitles are there because of your tv, there should be a button labeled "cc" on your remote. If you press this key a few times, it should eventually read something like "cc off" on the tv screen. I hope this helps, and good luck! Sincerely, Der Strom
May 10, 2010 | LG DR-4912 DVD Recorder
I have Technika TV (model Number 15.4-311) with
  • Remove any DVD in the player.
  • At the blue screen type 9735.
  • A menu should pop up. select region and then select the top option which should be region 0 (0= multi-region).
  • Next select exit setup then power off the tv. It should now play all regions.
I just did this myself so i know it works.
Apr 02, 2010 | Televison & Video
DVD not working Technika Pro 19
The failure rate on these Technika products is shocking.
My in-laws had a 19" which gave up completely just after the warranty ran out: power supply probably.
Our 15" TV/DVD now has a DVD drive failure. Just outside warranty, and on ours we hear several loud clicks.
Inspecting the slot at the side tells us that the DVD isn't spinning.
If you're lucky it's just the lens that needs cleaning, and you could use a cleaner DVD if you can get it spinning.
Or maybe it's the motor that's failed, or maybe the bearings have seized, or there's dust in there that's preventing the motor turning.
Who knows. These things are evidently not built to last. I'll not buy another.
Jan 17, 2010 | Televison & Video
I would like to be able to record TV shows WITH subtitles/closed captions. I have a Hisense HD LCD TV with built in HD tuner. I would like to be able to record onto a DVD/VCR. I'm getting conflicting...
Hey, I have a deaf brother with this issue. What I done was route the AV output of the TV to the AV input of the recorder. Set your recorders source to AV1 (or whichever you use) and set your TV to the program you want to record, also turn subtitles on. Because you wont have your TV set to the input your DVD recorder is on, you won't be able to see the DVD recorders output, but thats fine. Just press record on the unit - you have to leave the TV on the channel it's recording. Now you should be recording TV with subtitles with no problem :D
Apr 27, 2009 | Televison & Video
SANSUI HDLCD2600 TV W/DIGITAL TUNER
This is likely your DVD player, not the tv.
First go into the setup menu of your DVD player and make sure "subtitles" are turned off.
Next, put a DVD into the player and when it gets to the menu, go into the audio setup.
If subtitles are turned on, turn them off. If subtitles are turned off, turn them on and exit the menu, then go back into the menu and turn them off again. I've seen this reset this same problem on some DVD players.
May 06, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Closed captioning
You have to put in the language code by pressing setup in stop mode, select Custom, go to language select Subtitles, then enter in the code listed on page 31 of the manual on this website
http://www.emersonaudiovideo.com/pdf/om/EWD2203.pdf
Dec 25, 2007 | Emerson EWD2203 DVD Player/VCR
Televison & Video Logo
655 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
