If you don't have a local speaker "recone" service in your area, check on-line for raw speakers. A web search using the keywords "speaker" and "parts" should turn up a number of suppliers.
Dan
Yep, if it is a scratchy sort of sound, the units coil has overheated, the voice coils insulation has bubbled and expanded, and is now rubbing against the magnet as it moves. Only fix is to replace the driver. U can confirm by moving the inner circle of the cone in and out of the magnet. Should not rub and be perfectly centered around the magnet.
A vibration sort of sound can be caused by loose screws holding down the driver. But that is usually the case on your large heavy drivers with large excursions, not a mid range speaker.
hi,
check the tweeter and mid range. its coil may become faulty.
for checking the speakers carefully remove the speakers one by one, remove its connections.
and check the speakers with a AAA cell. is it producingcracking sound. if not the speakers coils are burned.
ok
All a Dual Core Speaker is, is Two speakers, sort of, in one. It has Connections for the Mid-range and Woofer, so The Inner speaker, is the Mid Range and the Outer, is the Woofer. Wire + to + (Red to Red), & - to - (Black to Black)
3 1/2" Mid range on dash, 6 1/2" Mids in the driver and passenger doors, 6X9"'s in the rear seat, and added (2) 10" Rockford Punch Phase 2 subs in the cargo area with a Rockford 3000 W. amp to power. Sounds Great!
