Question about Bissell 1770 Quicksteamer II Upright Vacuum
BISSELL QUICKSREAMER MODEL 2070
HOW DO YOU WORK THIS MODEL?
    President:
  • 1,673 Answers
Here is a link, don't know if it will work for you or not:http://bissell.com/images/UserGuides/1960.pdf
But you put you cleaning solution along with hot water in the upper tank, the bottom tank sucks up the water as you clean. Pull the trigger to dispense clean while pulling it back towards you, push it forward and repeat until done. If that link doesn't work, you can call Bissell and order a operator manual.
1-800-237-7691
Posted on Mar 30, 2008
USER MANUAL FOR BEX BISSELL PRO HEAT PLUS 2X + MODEL 9500-E
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
BISSELL 9500 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 15, 2012 | Bissell Vacuums
NO,LOOKING FOR MODEL#2070 FOR BISSELL PRO STEAMCLEANER, INSTRUCTION MANUAL
Model 2070 is listed as the Quicksteamer™ PowerBrush on the Bissell website. The User Guide for the 2070, although labelled for the 2050 is here:
http://canada.bissell.com/images/UserGuides/1950C.pdf
If this does not match with your model suggest you try browsing or searching the Bissell site to see if you can find a closer match.
Mar 24, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Lost instructions for Bissell little green pro-heat how does it work
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Oct 03, 2010 | Bissell 1425 Little Green ProHeat Handheld...
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
I have a Bissel Cleanview Helix, model #82H1. The
Bissell Cleanview Helix 82H1 Series User Manual
Ava B.
May 29, 2010 | Bissell 35755 CleanView Bagless Upright...
Do not know how to operate. no book
Without have the model number of your cleaner it is hard to give you a link to the correct user guide. I am including a link to a page where you can find your model and then next to the picture is a link for that model's user guide. If this won't work for you I am also including a link for customer support for Bissell. Hopefully this will help you to the point that you will give me a good rating. Best wishes.
http://www.bissell.com/Products/c/uprightdeepcleaner/Category.aspx
Customer support:
http://www.bissell.com/Customer_Service.aspx
Sep 22, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell model 1631 manual
Aug 30, 2009 | Bissell 1631 PowerSteamer ProHeat Canister...
I have the Quick Steamer Plus 160 Series/2070 Powerbrush. It will not release cleaning solution and will not pick up solution that had already been dispensed. Is this something simple I can fix???
I checked the bottom of the fresh water supply container and all was well there then I used a pin in the tiny air valve on the container. Turned the machine on, pulled the lever to release water and held it for several minutes and finally the water started to release and the machine works fine now.
Aug 01, 2009 | Bissell 1960-3 QuickSteamer Plus Upright...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
Brush belt is very weak.
Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
Apr 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Quicksteamer
Below is link to the directions for use for your vacuum: http://www.bissell.com/images/UserGuides/2070.pdf Just download to your computer and view with a pdf viewer or print it. Good luck.
Jun 13, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
Bissell 1770 Quicksteamer II Upright Vacuum Logo
171 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
