Router keeps disconnecting from the internet.
Belkin router keeps disconnecting ,first the telephone light flickers then the connection is lost and the internet light goes out. Had been working fine previously for 2 years!
    Sergeant:
    Champion:
  • 256 Answers
Its problem with telephone.
Posted on Mar 17, 2008
SOURCE:
I am using Belkin F5D7234 router.I can access the Wifi from my laptop very well but sometimes the internet connection is lost i.e in 1-2 minutes, the it automatically got connected and disconnects again...
While facing the problem, check the lights. Is it changing or not?
If it changes, The problem maybe with the router. Contact Belkin: 18002235546
If it is not changing, You need to contact the ISP.
Feb 21, 2011 | Belkin F5D7234-4 Router
My belkin N router always disconnects on the internet. im sure its not a modem issue coz when i try to restart my router its connected again to the internet. my belkin router model is f5d8233-4v3....
Disconnections are generally relative to the Internet Provider and Speed. If the speed drops, the router can disconnect and reboots. Just make certain you always update all drivers and especially if you are in Windows, keep up with current updates. Check your device drivers and do update from there also.
Feb 07, 2018 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
My wireless light on my router keep blinking red
Integrated Router/Firewall/VPN -40 to 85C, Immunity to EMI
Feb 28, 2010 | Belkin (F5D7231-4) Wireless Router
Belkin F5D8236-4 Wireless Router will not connect to pannaway dsl modem with same settings as router I am replacing. Dynamic IP address setup. Modem light continously blinks orange. No internet light.
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
Oct 03, 2009 | Belkin F5D8236-4 Router
How do i connect my router to my telephone line
The telephone line doesn't connect to the router. The telephone line goes to the modem which is provided to you by your internet provider. Then an ethernet cable is connected from the modem to the router.
The modem allows the internet connection to be active, The router is used to distribute the Internet to create a network.
Sep 16, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Router not allowing an Internet connection
It's not unheard of for a router to fail. When you connected the computer to the Modem, did you use the same cable that was connected to the router? Does your internet connection require a username and password? If so, is that configured in your modem, or the router? If not in the modem it must be the router.
Jan 05, 2009 | Belkin (F5D7230-4) Router (587009)
MY ROUTER KEEPS LOSING CONNECTION
Hello fieldon68, & to all the rest with the same problem.
There are many things that could be wrong, but intermittant discounnects sounds very much like a interverance from another wireless device. (ie phone, cell, etc)
To try to address this issue, follow the steps below:
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit ( unless you created a password, then enter that).
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
CauseYou get disconnected wirelessly mainly due to an environmental interference. When the wireless channel is set to auto, the router will cycle to though channels when it detects significant interference. When the router changes channel the wireless connection will reset itself and disconnect all wireless clients connected to the router. Wireless signals are prone to interference from cordless phones and electrical appliances (e.g., vacuum cleaners, microwave ovens). This is one of the more popular reasons Belkin wireless connections can drop. Good Luck Mark P.S. Please leave a rating.
Jan 02, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Router keeps frezing.
Try changing the channel of the router to 1,9 or 11, and make sure that there is no cordless phone near the router or the wireless computer, this will help mionimize wireless interference. If this may not work you may want to adjust some settings on the advance wireless settings of the router like the beacon(set it to 50) and RTS/fragmentation(2304).
May 07, 2008 | Belkin (F5D7230-4) Router (587009)
Open Questions:
LeXmarK Printer tEcH SupPoRt pHoNe nUmBeR{-1\855/~26O+0O64-} USffddA LeXmarK Printer ROUTER Tech Support Number +1{\855/*26O*0O64}Wireless Repair service center to resolve all LeXmarK PRINTER customer service phone Number products. LeXmarK Printer ROUTER is an American multinational company which was founded by Michael LeXmarK Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, LeXmarK Printer ROUTER support number, and selling of computer-related services and products. LeXmarK Printer ROUTER Tech Support Phone Number Recently, LeXmarK Printer ROUTER has been named the number LeXmarK Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, LeXmarK Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a LeXmarK Printer ROUTER Service Tag or a LeXmarK Printer ROUTER Get LeXmarK Printer ROUTER Technical Support Phone Number and Customer Services. LeXmarK Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 15, 2019 | Lexmark Computers & Internet
Computers & Internet Logo
216 people viewed this question
Ekse
Alun Cox
