Question about Sony Handycam CCD-TRV108 Camcorder
SONY HANDYCAM CCD TRV-108
It WILL record just fine..BUT when I try and play what I have recorded (past tapes and now) I will only get a blue screen. I can only see what I have recorded when I press and hold FFW or RW while in PLAY MODE. I have already tried cleaning the heads.
I called SONY to see if they make/made a VCR adapter tape for the HI-8 tapes, so I could just bypass using my camera to view my recordings...but they dont.
What is wrong with it?
  • chels30 Mar 17, 2008
    How do I fix the alignement...? And how much would it cost if I personally can't fix it?
All of a sudden no picture appears on the screen when recording or playing back. It will play old tapes that have been recorded, but won't record any new pictures, just sound. Did I press something? It worked a month ago and hasn't been used since.
Posted on May 02, 2008
    President:
  • 4,402 Answers
Tape path is out of alignement
Posted on Mar 17, 2008
SOURCE:
Sony ccd trv 308 had a error c 31:23 and c 31:22 , beeps when trying to play and record. Found the pinch roller jam inside , took it out and fixed it with heat shrink tube, error gone , camara runs good ,...
Did you possibly hook it up right to your tv? Where was the blue screen. How do you know it recorded anything if your not sure if it works right. Is the tape moving? Sometimes it may appear to be moving and really it's not. Hear isn't a good thing with a tape recording device. I know this might sound trivial, but I would read the directions if ya got them and make sure your not skipping a step. If you record on some machines you have to switch from record back to play mode. Where is the blue screen.
May 20, 2014 | Video Cameras
Hi sir. I thing i need drivers to my ccd-trv 108 e handycam to get my video int my pc. I have windows 7. And i want driver to my dcr-hc23 to.....is that posebul you can help me. ...
your sony ccd-trv 108 will transfer videos(stream) to a computer using firewire connection. install the supplied software or use any program compatible for streaming like windows movie maker. use a firewire cable. check your computer for a firewire port(port with IEEE symbol) make sure that the tape is totally rewounded then press the record button on windows movie maker as the same time as you play the video from the camcorder. (its basically playing the entire video in order for windows movie maker to record it.
Jan 25, 2011 | Sony Handycam CCD-TRV108 Camcorder
Does not record video but records audio. will
Pushed the reset button under the flip out screen and viola it worked AOK.
Jan 04, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
May 10, 2009 | Sony Handycam CCD-TRV58 Camcorder
Error message
What does a drum motor cost and where do you get that replaced at?
Nov 09, 2008 | Sony Handycam CCD-TRV108 Camcorder
SONY CAMCORDER CCD TRV 328 rec,problem
Your camera ccd-TRV328 has defect with ccd imager that's why not giving picture in camera / recording mode. This part (ccd imager) needs to be replaced and good news Sony will replace it free of cost.
Please click Sony Official Website for details.
Regards,
Sep 02, 2008 | Sony Handycam CCD-TRV328 Camcorder
Tape path out of alignement...?
the link is for a DSC-T33 is that what you have?
either way i would have to say tell you unless you have experience working on these i would send it in or take it to a repair shop.
Mar 17, 2008 | Sony Handycam CCD-TRV108 Camcorder
My Handycam corder do not record
I had a similar problem and it turned out to be my zoom was to the max. All I had to do was zoom out.
Aug 20, 2007 | Sony Handycam CCD-TRV128 Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Sony Handycam CCD-TRV108 Camcorder Logo
643 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
