XP Reboots by itself on arrival of login screen
I got two hard disks both of them installed with XP service pack 2 with the same cd ( I kept only 1HDD attached to the system )
To get some data
I did removed the attached HDD and attached the second one to the cable, and the XP started getting restarted, it kept rebooting
Now I again again installed the 1st one on which I got the same error, XP gets rebooting itself at the boot screen itself
Finally both of my HDD with XP sp2 are giving me the same error
"Rebooting at the boot screen continuously"
Any Suggestions
  • Anonymous Mar 03, 2009
    you turn the computer on and it turns itself off and on
  • 871 Answers
Have you tried safe mode? if safe mode is still a failure, you have no choice but to reformat 1 of those drives an do a clean installation of windows xp
Posted on Mar 17, 2008
SOURCE:
Difficulty to open pdf files
1. Make sure that the system meets the requirements for the Acrobat product that you use.
Acrobat can't run correctly if the system doesn't meet the following requirements:
  • Intel Pentium processor
  • Microsoft Windows XP Professional or Home Edition with Service Pack 1 or 2, or Tablet PC Edition, or Windows 2000 with Service Pack 2
  • 128 MB of RAM (256 MB recommended)
  • 460 MB (Professional) or 360 MB (Standard) of available hard-disk space; optional installation files cache (recommended) requires an additional 300 MB of available hard-disk space.
  • 1024 x 768 (Professional) or 800 x 600 (Standard) screen resolution
  • CD-ROM drive, if installing from a CD
  • Internet Explorer 5.5 or later
Jun 16, 2011 | Adobe Acrobat 7.0 Professional
Windows does not boot up unless i have system disc i have reinstalled xp but it stops and says boot from cd put in system disc xp everytime i try to start it up then it will start i take out the disc and...
Have you let the machine complete the install? There are a couple of reboots with the disk installed. Don't press any buttons during the reboot the disk will transfer to the harddrive when appropriate.
You also may have a corrupt boot record. Next time try booting from the CD. When the system comes up, select recovery console (R). When you are asked for a system to login, press enter. Enter the administrator's password if asked. At the prompt, "c:\windows>", type fixmbr.
May 16, 2010 | Microsoft Windows XP Professional With...
Intel d845ebg2 cannot setup windows pls help
You probably added the wrong Ram memory. Some if those 512 memory, are not suitable for windows XP and UP.Try removing the 512 Ram module and see what happens.
Good luck.
Nov 07, 2009 | Intel Desktop Board D845EBG2 Motherboard
Installallation of xp
the xp does not recognize the SATA hard disk of your computer, you must install SATA drivers during the installtion of XP.
Sep 16, 2009 | Microsoft Windows XP Professional With...
Original "XP-Professional Disk" loaded - Will NOT accept svpk
Hi there.
When it get to the point where it cannot install the service packs, if it gives you an option to skip the files then do that and let XP install as usual, when its installed perform a Microsoft update and update the machine, this will no doubt take hours because if the disk is 4 years old it will want service packs 2 and 3 installing so make sure you set the computer to never shut down or go to sleep.
Good luck
Jun 11, 2009 | Microsoft Windows XP Professional With...
Locks up during installation process at a random percentage of completion
If you have sufficient hard disk space, copy SP2 from the CD to the hard disk first and then install it from there.
Jules
May 04, 2009 | Microsoft Windows XP Professional SP2
Was told I need a new HD on my T3504 so I put one in
you should make use of the original Microsoft windows xp service pack 2
Jan 13, 2009 | E-Machines T3504 PC Desktop
Reformatting problem
Do you mean that you are re-loading windows? if you are when it reboots after re-loading and it says boot/start with cd-rom support do not press enter again or anything else for that matter because if you do it will keep taking you through the whole process again. Once it has loaded and reboots do not press anything it will start windows( even though it gives you the option to start with cd-rom support - just ignore it), itself and take you to the welcome screen etc... once this happens you can take the disk out.
Oct 25, 2008 | Computers & Internet
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Jun 30, 2008 | Acer Ferrari 4000 Notebook
Continuous loop and cannot charge battery
Windows service pack 2 is a huge update and takes a long time to complete, I will suggest walking away from your computer and having lunch, go to sleep, watch a movie, etc... while the update finishes. If you have already done this with the same result? I would look for a Windows XP SP2 disk (XP with service pack 2 integrated) and try that. Otherwise Microsoft sent out many disks containing the SP2 update itself on a disk, and you could try the SP2 update from one of those (if you can find one) after your clean install.
Good luck.
Feb 24, 2008 | Toshiba Satellite Pro M15-S405 Notebook
Open Questions:
Outlook toLL free number +1-844:819,3382 USA OutlooK toll free numbeR Outlook toLL free number @+I844~819~3382 Get Outlook Setup • outlook tech support usa • outlook technical support number • outlook tech support phone number • outlook customer service live • outlook tech support email • outlook support number • outlook support • outlook toll free number tMICo resolve all Outlook errorS. OUTLOOK is an American multinational company which was founded by Outlook using its company headquarters in Round Rock, United States of America.Contact Outlook for Setup & Installation Outlook Setup toll Free & Installation Outlook Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Outlook Connect, Outlook Helpline Phone Number you'll be searching out Outlook Connect setup as well. So, here we're with all cthe setup process and for your to Outlook Connect. Instant toll Free Outlook Toll free Service Phone Number Usually, the setup technique takes a number of time. One technique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may OUTLOOKAntivirus locate the approaches simplified to help you even if you aren't Toll free -savvy. Let us undergo the method Of Outlook Connect setup for Windows and for Mac Out. So, Outright here we go thirdpartie_
Oct 18, 2019 | Carrier Computers & Internet
Computers & Internet Logo
245 people viewed this question
Ekse
Alun Cox
