GE Security Simon 3 Wireless Home Security System Logo
Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Having problems programming the door sensors on a GE Simon 3 unit. I get the units to communicate with the panel but every time some one goes in or out the door the alarm goes off and scares every to deat. Also, I can not get the unit to let me know when someone opens the door, the chime feature.
Anonymous
Level 2:
New Friend:
  • Expert 74 Answers
  • Posted on Sep 05, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
74
Questions
0
Helped
47572
Points
116
It sound like you are programming the sensors as a 24 hour zone. They need to be either a type 10 (entry exit) or type 11 perimeter.
Alarmprofessor.net
Simon 3 motion sensor
If your motion detector act like a door it is because it has been program like a door, you need to go back to the program delete your sensor, and reprogram it with a group 17 , right now it's probably program as a group 13 ( instant)
Program simon security system chimes
To turn the chime on for your door/window sensor on a Simon 3 panel push the "chime" button on the keypad. Hope that helps!
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Trying to add 10 window sensors to existing GE Simon 3 control panel that currently has just motion detect, glass break detect, and 3 door sensors. How to install and program them to work? Thanks you,...
First you need to have the installer code. Open the fromt panel of thealarm and enter in "4-3-2-1" (Default installer code) If it accepts this number then you can begin to program the doors and windows. If you don't knowtheinstaller code you mayneed to default the system and reprogram everything. If you contact meIcan walk you through the processor.
AlarmProfessor.com
2answers
I have ge simon 3 - Purchased ion micra -g wireless window and door compatible sensors. Didn't come with how to add sensor. Wants me to push button on sensor; where is that button
I'm having the same problem on a used Simon. I think the button is inside the wireless transmitter. It has a spring attached to it. Just press on the spring to send wireless signals to the panel. My problem is I press on the spring and the panel does not receive the signal, even with a $20 fresh Lithium Ion battery from Radio Shack.
Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
2answers
I have ge simon 3 which suddenly says phone not
you may have had a lighting strike to the phone line causing a surg to your unit. it may be fried. try completly powering down the system and powering it back up, then try to send a signal to your monitoring station. also you my have your monitorimg station try and connect to your system and check the programing it may have been scrambled.
mj
I can not get the GE Simon 3 to call out or in.
reverse dial tone and out to phone on block. Blue/White and Brown Yellow. Also check that Both ends of 8 pin jack is plugged bin all the way.
GE Simon Security System - help!!
The default for option 10 is 30 seconds and option 11 is 60 seconds.
It sounds like option 10 is turned off because when turned off the entry delay is set to 005 seconds. All entries must be 3 digits.
You ca set option 10 and 11 from 005-254 seconds. Hope this helps
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
