Question about Cameras
Cannot find usb lead to link camera to computer, need to locate a lead/
    Genius:
  • 2,985 Answers
Any computer/camera store will do them.
Posted on Mar 17, 2008
2 Suggested Answers
  • 102366 Answers
SOURCE: how do i charge up tthe kiddizoom camera for my
The Kidizoom uses four standard AA batteries. You may use disposable alkalines or rechargeables. If you choose to use rechargeables, you much charge them using a separate charger. The Kidizoom is not a battery charger.
Posted on Oct 27, 2011
Have not used this for some time , forgot how to put picture on computer , cant find lead , what lead do I need also I have change my computer , do I need a install a new progamme,
probably need a lead with a mini usb end at one end and a usb2 end at the other
with a new computer you will have to down load a driver for the camera
take the camera to a camera shop for user advice and the lead
May 04, 2015 | Cameras
My computer no longer recognizes my Panasonic mini-DV recorder. I am using USB 2.0, but the device manager does not even recognize the camera. I have even tried multiple USB ports, all to no success. I...
Vista may not support it but you can try some things.
oYou may need to simply and very carefully delete all usb devices from device manager and restart so they are reseen and re-installed.
usb devices in devices mgr link
Google
I would take the time to look at some of these help articles to determine how you wish to proceed:
more at this link
Google
this is a differentr camera but may also give some leads to discovering the issue:
Connecting Sony Handycam to Windows Vista Via USB
Google
Mar 25, 2017 | Panasonic PV-GS35 Mini DV Digital...
Require a lead from camera to PC ( usb on one end)
This is one of the few models of Digital-8 camera that can transfer video to computer with a USB lead. It will be USB at BOTH ends, but the camera end will be a miniature version. Don't confuse it with the Firewire connection (Sony call this i.Link) which is different and incompatible with USB.
I found several USB leads for this camera by searching Amazon for "DCR-TRV140E usb". The cheapest was about $3.
You can access a Sony tutorial for downloading from this camera, and other information and downloads, at THIS LINK
Jan 22, 2011 | Sony Handycam DCR-TRV140E Digital...
Hi im trying to transfer 8mm tapes to my computer?i have down loaded new software but when i hook up computer says it cant locate i,link cable?i have hooked up provided usb cable but it wont reconize it?
This type of camera usually downloads better with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 cameras only use the USB connection (if they have one) for stills and can ONLY download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The DCR-TRV265E definately has to use Firewire.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Digital8 as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Jan 04, 2011 | Sony Handycam DCR-TRV265E Digital...
How do I import video from my sony handy cam DCR HC32 via USB to my computer
You don't. According to Sony, your camera will not stream video via the USB port. You can only do this using the i.Link connection (what everyone but Sony calls Firewire). The list of camera models that will stream via USB, and the method to do it, is on THIS LINK Your camera is not in the list.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. Or maybe you have a Mac. You haven't said.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select your operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Jan 03, 2011 | Sony Handycam DCR-HC32 Mini DV Digital...
When I plug in the usb lead to download the pics, the camera screen goes black as if off, i unplug the usb lead and the camera resumes normal function, do i need a new usb lead or is the problem something...
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 15, 2010 | Vivitar ViviCam-X30 Digital Camera
What type usb lead?
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 20, 2008 | Casio Exilim EX-Z55 Digital Camera
No software for fuji finepix A204 GOT CAMERA AND USB LEAD. NEED SOFTWARE TO DOWNLOAD PICS.
go to the link below for the driver, you dont need software as you can explore the camera in my computer and copy then paste the photos, but windows may come up with picture viewer when you connect the cam up to the pc
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a204-zoom/support
Aug 29, 2008 | Fuji FinePix A204 Digital Camera
Reply
Hi there again,
I am assuming you are using XP OS.....
I have a couple of questions for you.
Try this.............
With computer on and camera NOT connected,
Please look at my computer,
1.What happens when you connect camera to usb lead then connect the lead to the computers usb port?
2,Would it upset you if we use another way of moving your photo and video files from camera to computer?
3.Does Memory card work in another device or computer?
Solution 1 =================================
If usb did not recongise the camera on the usb port then it will be a software and hardware reinstall ,
Remove usb lead from computer
Go to Add/Remove from you control panel.
Remove the cameras software.reboot.
restart install software first and reboot,
do not connect camera yet,WAIT.
once restarted add camera via usb
should be good to go.....
If it does continue to give you issues then consult the manufactuerer.
Solution 2 =================================
if the usb is connected to the camera via usb lead to usb port on the computer and you can see the cameras' drive info then its more than likely you will be able to open and use this file ,if so you should be able the move these files to your computer too.
Solution 3 =====================================
Explains itself really-Replace it if you need to.
Hope this sorts out your problem.
I beleive your card reader may be poked,
Uninstall and reinstall try again, replace if presists.
these solutions I have put forward have been proven to work in many situations so good luck and let us know the results thanks
Jul 16, 2008 | Computers & Internet
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
