X2gen MV19 monitor: can only get VGA resolution
I know this is a cheapo monitor, but surely there's a way to improve resolution?
Although monitor settings show 1280 x 1024 @ 75hz, resolution is horrible, and monitor pops up a box with "VGA" in it.
Old Dell desktop, with 32mb ATI Rage 128 Ultra video adapter, best I could get was generic "Plug and Play Monitor" in display settings?
This monitor replaced a Nokia CRT display which, although ancient and the size of a school bus, displayed higher resolution.
  • 85 Answers
Unscrew the monitor check behind the line transformer you will see two buttons for adjustment use them to increase your resolution manually
pls make sure the monitor is shut down for abt 15-30 minutes before you attempt opening it to avoid electric shock
Posted on Apr 22, 2008
It says that its out of range whats going on with it
It means that the signal sent by the graphics card is incompatible with the monitor display resolution
Try rebooting to VGA mode and in Control panel, adjust the display settings
Jan 07, 2011 | X2Gen MG19MY 19" LCD Monitor
Need driver download have new tower and lost CD for monitor X2GEN model MG19MY
Most monitors do not need additional drivers for them to function properly in Windows XP, Vista, and 7. If you are not able to set the monitors native resolution then look at your video card drivers. If these are not up to date, then you can see some very odd default resolutions.
Mar 27, 2010 | X2Gen Computers & Internet
Do you need a special driver for x2Gen 22 inch monitor with windows 7
You do not need drivers for monitor, just make sure you set the resolution output of your video card to the monitor native resolution and set the refresh rate to 60Hz. Make sure you do have win7 driver for your video card.
Jan 05, 2010 | X2Gen MW22U Monitor
I have an old X2Gen MG19MY flat panel monitor with no drivers
It may be that you just need to download drivers for the monitor from manufacturer web site, and insstall. depending on how old the system is, video card may not be able to handle the operating system if it is using shared memory with the video card. Not enough info. did it all work on the previous operating system, and what resolution did it run at.
elah4@zoominternet.net for more info, to help with problem.
good luck
Rodger
Jan 01, 2010 | Computers & Internet
When i plug my computer in to the vga port i get a message on the screen saying out of range
That message is usually a sign that the computer is set to a high resolution, and the monitor doesn't support it.
You can go to the Settings and change it to a lower resolution
Don;t forget to rate this answer if it helps
Dec 12, 2009 | X2Gen Computers & Internet
Monitor says out of range when i start windows 7
When you start the computer, press F8 continually until you get a menu that will allow you to start in VGA mode.
You apparently have the resolution set too high.
You may be able to reset it in safe mode, also.
Nov 04, 2009 | X2Gen MG19VT 19" LCD Monitor
New computer, monitor issu
when you power on the computer ............after a second press F8
then advance boot option come after thet there is a option"enable VGA mode ............." press enter .finally window start up
then goto display properties and change the refreshing rate of moniter.
Apr 05, 2009 | X2Gen MG17J 17" Monitor
Out of Range
Usually with the resolution your computer's set resolution for ur display is to high for the screen
try using a different screen to change the frame refresh rate and resolution to ur monitor
Oct 21, 2008 | X2Gen MG19MY 19" LCD Monitor
Computers & Internet Logo
537 people viewed this question
Alun Cox
David Payne
David Payne
