Question about Ovens
Oven and Stove top don't heat up but indicator lights on
My oven and stove top do not heat up but the indicator light comes on so I am assuming there is power. Is it the fuses? It worked fine up until this weekend March 15th 2008.
Steve
  • 2 more comments
  • skt99 Mar 19, 2008
    Thanks for the tip but that didn't work.
    I tried the plug/outlet on the stove and there was no power there either. Could it be the fuses in the range or something else inside?
    Thanks
    Steve
  • skt99 Mar 23, 2008
    I took the back off and the porcelan block where the power source connects to the oven was fried. Went to a local supplier who said if the connections were loose it could arch and fry the connection. Luckily this was one of my rental properties and not my home. The new part was $10 and took about 5 minutes to install. Work fine now.
    Steve
  • ryan3144 Oct 02, 2008
    Top burners and broiler works but the oven will not heat up. Any suggestions?
  • Anonymous Mar 26, 2014
    top of stove works but oven only heats slightly
    President:
  • 2,651 Answers
There may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
Posted on Mar 18, 2008
  • Ron Coons
    Ron Coons Mar 19, 2008
    you said there was no power at the plug/outlet>?? how old is htis unit and who makes it??
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
Americana stove not heating but lights come on
get in an electricians to check what looks good but isn't
May 29, 2017 | Ovens
I have the fisher paykel pepper electric stove top and oven at home. the stove is working just fine, but below it the oven turns on but it doesnt heat up. what should i do?
When you say that the oven turns on I assume that the oven indicator light is working. If this is so there will be only two likely causes for the oven not working.
Oven element is faulty - check by performing continuity test;
Wiring at oven element terminals burnt off - check visually.
If you are handy carry out the above. If not, call a repairman.
Feb 15, 2011 | Ovens
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
GE Evolution stove/oven. My oven is not working,
remove heating element an check with ohm meter. pretty simple really.
Jun 12, 2009 | GE Ovens
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Installed a new Tappan stove electric
check if there are links on the mains connector block and if so, make sure they are tight
Aug 10, 2008 | Tappan 30IN ELEC IGNa Oven
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
927 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
