POWER OUTPUT OF A SHEERWOOD AMP MOD NO AX-4050Rwhat
What is the power output of a sherwood amp mod no ax-4050r ser no 9708a020238 and what type of speakers would one use??
  • Anonymous Apr 02, 2008
    technics amplifier with choice of 8 or 16 ohms
  • 682 Answers
100watt-rms.
Posted on Apr 26, 2008
Ax-15 transmission input shaft seems to be short going into 4BT cummins motor
that ax-15 , behind cummin's.
3.9L , 50 lbs more torque, there, may be ok.
when buying custom mod. cars this is all normal.
1: nobody can fix your car, due to its not stock.
2: get stranded on the road, far from home and nobody will wont to touch it..
3: finding out just what the hacker did to make it work, now that takes alive human to do that... for sure.
hacker=modder=custom jeep.
you may need to go to jeep.com
and look at every front pinon shaft ever used
on the ax-15
my guess just 1.
it's too short because you have 3.9L cummins to Ax-15 adapter
there, and the mod guy, just ignored this.??? no photos presented by you.
my guess, (wild)
is it's this?
http://www.jdjeeps.com/jdjeeps/adapters.ashx
we are blind here can;t see all those custom parts
not hardly
if you look there
it has recessed plate to make the distance match.
and mounts match.
and has a custom collar for the throwout to slide on.
all custom parts.
and many suppliers. unknown yours.
Mar 25, 2016 | 1993 Jeep Wrangler
Sherwood ax 3030r
What is the question? More information is needed before somebody can help you. What type of watts are you asking, power input, output, music, RMS, etc.
May 14, 2014 | Audio Players & Recorders
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
Sherwood ax 4050r
'Direct' disconnects the EQ normally. Don't trash your amp because of a noisy EQ when you can bypass it.
Mar 05, 2014 | Audio Players & Recorders
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Sherwood AX-7030R amp - doesn't switch on.
Something doesn't sound right. The standby circuit is usually very simple. The "regulator" is just a transistor. Can you request and post the parts that he/she can't find. I should be able to get you a source or substitutes.
Dan
Dec 16, 2008 | Sherwood A-965 Amplifier
180 people viewed this question
 Grubhead
Grubhead
