Question about Compaq Presario 700 470024-192 Notebook
Removal of cd/dvd tray from acer aspire 5051
Hi, Do I have to remove all the bottom panel to get at the cd tray or is there a simpler way to remove it ? Also the Acer Aspire 5051 is not listed on your list so I have chosen the 5100, I hope this will be ok to do this.
Thanks........John
I want to change my cdplayer in my presario 700 for a dvd.
Can't find a way to remove it.
  • 117 Answers
Hi
turn your laptop back there you can notice a closers like ram, hdd and cpu
remove the ram closer there you can see end of the cd drive, Before that screws which is indicate with the cd symbol,(see near the drive tray carefully)
then gently push the cd drive catefully from the back side , under the ram drive
Posted on Mar 19, 2008
Acer aspire 5738 cd DVD drive not working
1.start>control panel>all control panel items>AutoPlay
change settings for each desired media
2.update the drivers for the DVD drive. search in all programs for the program name, go online and download the most recent driver
3. you may have mulitple programs that controll DVD/CDR reading ability. this will sometimes confuse/conflict the drive. try removing one using add /remove programs from the control panel.
Oct 05, 2012 | Acer Aspire Notebook
How to remove cd/dvd drive on a acer aspire 5003WMLi
Turn the laptop over, on the bottom you will find a screw about 5-6 inches in from the cd-rom drive. The screw will have a little symbol of a CD next to it. If you remove this screw the cd-rom drive should slide right out. Be sure to do this with the laptop turned off, unplugged and with the battery removed.
Sep 19, 2012 | Acer Aspire 5002 Wlci Zl5 - 5000 Series...
Acer Aspire Am3470g case removal
I also have an Acer Aspire AM-3470G & just swapped DVD drives trying to troubleshoot a problem. Remove the one side panel with the finger tab that gives you access to the system board/HD's, etc. No need to remove the opposite side panel. With the panel off, there are 3 black plastic tabs holding the front cover on. Release them so that the front panel pivots to the opposite side which also has 3 black tabs. Those tabs will release themselves as you pivot the front cover. You may need a bit of force to pivot the cover so be careful not damage the plastic tabs. You'll now have complete access to the DVD tray area. The DVD is held in by 2 exposed screws, there are none on the opposite side of the drive. Unscrew them, disconnect the power & SATA connectors & slide out the drive. If you replace the DVD drive, test the new one before you reassemble all the covers to verify everything works.
May 04, 2012 | Acer Aspire Am3470g-uw10p
Replace cd writer in acer 5742
Flip the laptop over to expose the bottom where the cd driver is, you should see a release button or screw, "someimes 2" remove screw and get a fine pin to insert in front tray hole, push in until you hear a click, pull tray out along wth the main drive unit.
Apr 12, 2012 | Acer Aspire 5100 Notebook
My Acer Aspire. Will npt eject the disc but the tray comes out leaving the disc in side laptop, I may have ommitted to click the disc down on to the tray, please help your assisitebce appreciated.
You need to remove the CD/DVD drive from the laptop and then dismantle and remove the cover from this drive to get access to the disc.
After removing the disc, replace the cover and install the CD/DVD drive into your laptop.
Apr 07, 2011 | Computers & Internet
Cannot remove old dvd, seems stuck while trying to slide it out
Push a large paper clip or something similar into the little hole on the front of the CD close to the tray. Pushing it in will release the CD tray.
Oct 17, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
I have an Acer Aspire 5670 Note book Computer
There is a small hole on the face of the tray which is used to open the tray in this kind of situation. Use some needle and push into the hole. If the tray does not come out, you have to open the laptop and remove the tray.
Sep 20, 2009 | Computers & Internet
How do i replace the dvd/cd drive? acer aspire 9410Z
Hi there.
Eject the CD tray and turn off the laptop, underneath the laptop you will find a screw that holds the CD/DVD in place, once you have removed the screw pull gently on the tray and it will slide out and you can install the new drive.
Good luck and thanks for using FixYa!!
May 11, 2009 | Acer Aspire 9410 Notebook
Look on the bottom of your laptop on the side where your cd drive is. There will be a screw that is centered with the cd drive, about 6 inches in. It should have a "lock" symbol next to it. If you take that screw out, the cd drive will be allowed to slide out then. You might need a screw driver to help pry it out though.
Jan 12, 2008 | Acer Aspire 5100 Notebook
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Compaq Presario 700 470024-192 Notebook Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
