Question about Microwave Ovens
Our Engineering Compamy Here In CANADA Montreal Quebec, Is Recommending To Use A 20Amp 2P-120V GFCI Breaker To Split A 15/20---120V Receptacle?? I Heard From Siemens Canada, That We Can Connect The Split Duplex With 1 X 20Amp GFCI Breaker Only Or Connect The Top Blades With GFCI & The Bottom Blades With An Ordinary Circuit. Customers Requirements Is A Split 15/20 GFCI Protected. Please Let Us Know What Can Be Done??? Michael-Gallant E-Mail mgallant@britton.ca Thank-You
  • Microwave Ovens Master
  • 9,098 Answers
First of all, is this to power a microwave?
If so, it is always recommended that microwave be on it's own breaker with nothing else attached to that breaker. This is due to the typically high current draw (12+ amps) of the oven.
The most important items which should be on a ground fault interrupter are those which may fall into water or get wet, but it's of course never a bad idea to use a GFI.
If this doesn't answer your question, please rephrase it with some more details.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
I have a 2000 23ft comfort travel trailer, it is pluged into electrical, all lights work, but I do not get any power from outlet plugs. I checked breakers & fuses, no outlets work.
On my trailer the gfci is a seperate button in the fuse panel that shuts down the 120v outlets, all the lights run off the 12v so they continue to work, does your microwave and ac work?
Mar 02, 2015 | Microwave Ovens
Whirlpool microwave gh7208xrb-3 fuse is good but the unit has no powernothing lights up at all it like it is dead.
Control board might be dead. Cost is quite high could run up to $200 or more. Many times I recommend just to replace it. Here's the dumb question, is power present at receptacle?, if over range microwave, in cabinet above microwave? Check for gfci receptacle tripped. Sometimes fuses appear good, always be sure to test with a meter.
Oct 28, 2013 | Microwave Ovens
I was just using the microwave and it died on me. No power to the unit that I can tell.
Check the circuit breaker. If it's pugged into GFCI type outlet or an outlet that's run from one, make sure the breaker didn't trip there.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Sometimes, only sometimes, mhen we run the
your microwave is ok, your breaker is bad or is not strong enough for the microwave. microwaves need a dedicated 20amp breaker
Feb 04, 2010 | Emerson MW8107WA Microwave Oven
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
I went to use my mirowave & it is completely gone. I pushed every button that I could & nothing happens. What should I do
first check the breaker in the electrical panel. your microwave should be on a circuit with nothing else. Depending on when the house was constructed. If the breaker is tripped turn it off and back on. If the microwave is plugged into a gfic outlet check to see if the receptacle needs reset. There will be a reset button on the receptacle. Their may be a orange light on the receptacle.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
JE2160WF02 was working, then shut off and will not power back on - circuit breaker OK
there is also a gfci plug in the kitchen that works like a breaker...find it and press reset.......there is also a fuse inside a microwave
Nov 17, 2009 | GE JE2160 Microwave Oven
The microwave stopped working
Ck your gfci breaker in your wash room or bath room. If this dosn't fix it it may be an internal fuse. If this is the case you will need to find what caused breaker to blow or it will happen again.
Aug 21, 2009 | Microwave Ovens
Break my glass plate inside my micro wave
You might do better to replace the microwave. My plate broke and would cost $27 to replace. I bought a new microwave for $40.
Jan 30, 2009 | Microwave Ovens
BROKE GLASS TRAY IN MT660 MICRO WAVE UNIT
Contact info for Rival should be in your owner's manual.
If not, maybe the dealer has that info?
Not sure if Rival US will help, but:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
Good luck.
Jan 04, 2009 | Rival MT660 Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
