Question about Jl Audio 500/1 Car Audio Amplifier
500/1 and 300/4 jl
I got the 500/1 ran to the 300/4 but when i cut it up it will cut out for a min
    Novelist:
  • 108 Answers
Need more info here. did you run power from the 500/1 to the 300/4, or did you run the signal from the 500/1 to the 300/4? Also which amplifier is cutting out for a min...the 500/1, the 300/4, or both? each amp should be wired to a distribution block with 4 awg power wire recommended for each. the amps should also be wired without any capacitor.
Posted on Aug 03, 2008
Hi, I have just replaced the cylinder head on my pajero 2.8 diesel. It started first time and ran for about 4/5 mins then cut out. It is attempting to fire but won't.....any ideas would be grate
Keep pumping the hand bleed pump on top of the fuel filter to remove all the air. when started and still a bit lumpy keep pumping and it should clear itself
Dec 03, 2012 | Cars & Trucks
Jl audio 12w3v2 sounds like its blowing air out of box
if you cant see a physical cut or **** in the rubber surround or anywere else you can try to check the wires going from the plug to the actualy speaker itself on the back of the speaker if those are fine then its probably blown if its not that old you can try and contact jl and see if they will replace them i know kicker has some kind of replacement system in play not sure of jl
Feb 28, 2010 | Jl Audio 12W3 Car Subwoofer
1 10 jl jl 250/1 mono block amp cuts off an on help
your subwoofer is wired incorrectly to your amplifier. Figure out which ohm load of subs you have and then what ohm load options your amp is stable at. Next go to either the Crutchfield website. find their learning center. go to subwoofer wiring diagrams. or go to www.the12volt.com and find their section on it
Jun 11, 2009 | Jl Audio 250/1 Car Audio Amplifier
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
My Subwoofer cut in and out intermittently how do I stop this?
Take out the actual cone and check the connections to the terminals.
Check earth connection!
Apr 04, 2009 | Jl Audio Slash v2 250/1v2 Car Audio...
Three jl w3 single coil
You can't run parrallel on 3 single voice coil subwoofers. If you run all the negatives from each coil and possitives from each coil to one terminal you will be dividing the ohms by 3. I don't think JL ever made a single voice coil 2 ohm subwoofer though. If you ran a parrallel on 3 8 ohms you would be at 2.7 ohms. 3 4 ohm would put you down to 1.3
Feb 27, 2009 | Jl Audio 12W3 Car Subwoofer
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
Jl audio 12w3v4....both smoked and fried on a 500/ jl amp
Unfortunately, it sounds like the voice coils burnt up. There are places that do repair, but for these particular subs, it would be more cost efficient to replace them. I also doubt they are salable, but ebay is a magical place.....
Mar 05, 2008 | Jl Audio 12W3 Car Subwoofer
Jl audio e6450 cuts out above mid-volume
take a look at the power, ground and remote wires. the power and ground should be a minimum 6awg in wire size, and the remote wire at least 12awg. it sounds like your drawing a lot of power,so smaller wires usually mean more heat...the amp will turn off into protectedmode if it gets hot or is used for along period of time,so on any road trip make sure if isnt msothered by sleeping bags,coolers etc...just like any major electronic component, it needs room to col off.
Sep 02, 2007 | Jl Audio E6450 Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
175 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
