Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer stuck on 7 min
I have a small load in the washer and it sounds like the machine is coming apart then the timer sits at 7 minutes forever. I rearragne the load (it doesn't appear to be out of balance) and try the rinse and spin cycle and again it sounds awful and sits on 7 minutes. I also have conintuning problems with the machine ruining all my towels or anything with any nap to it. The machine is less than 2 years old.
  • 3 more comments
  • Anonymous Mar 17, 2008
    Same problem -- Now it is displaying PF
  • joedontfixit Apr 05, 2008
    I had a clogged drain from under wire bras 8 wires stuck in discharge had repaired and my washer is stuck on 7 mins also . The repair guy is coming back .I will update when its fixed
  • Anonymous Apr 27, 2008
    Mine does the same thing. I have a GVW9959KQ2 and Friday night when I tried to do a small load on the Whitest Whites cycle. It was squeaking something terrible as the tub moved around and then it got to about 29 minutes and quit counting down even though the cycle was still running..then it gave me an OB error. I readjusted the load and restarted..then I got the LD error. The clothes were washed, it just needed to be rinsed and spun, so I tried the Rinse & Spin cycle. It tried several times but kept giving me either an OB or LD error, so I removed the clothes, rinsed them in the sink and ran a load with nothing in it. That time, it started making whirring noises as it washed, then would give me another OB error. It got to about 7 minutes and would start to spin but stop..go back up to 8 minutes and try again..then back to 7..then 8 again..then I stopped the cycle. I canceled it and started over only to have the same thing happen.
    I also noticed that at one point, it jumped from 19 minutes to 12..then got stuck on 7. I'm assuming that's a programming issue and not a mechanical one??? I feel sure the water pump is probably clogged as I've noticed lumps of wet lint come out a small hole at the top of the tub just under the back part of the lid...but I'm wondering if a circuit board needs replaced or something else along those lines. There's also water leaking and being splashed out the side and back during the wash cycles. Any suggestions??
  • Clouddancer Jun 03, 2008
    Same problem! Mine's stuck on 8 mins and won't change...won't start again...nothing! I unplugged the power thinking maybe it would reset itself but that didn't help. As soon as it was plugged in it was at 8 mins again. I'm not sure what the heck is wrong. Any answers?
  • Anonymous Oct 02, 2008
    sticks on 8 min rinse, unplug, it resets to 8 min,
    I think it is the Chinese
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
  • 290 Answers
SOURCE: whirlpool gold top load washer (7 months old) won't agitate or spin
It sounds like the motor drive coupler has broken. This means the motor is no longer turning the gearcase, but it is turning the pump. It will be repaired under warranty if it is only 7 months old. You should have a full one year warranty on the washer. If not, he can probably fix it, but it will need a new coupler. He can tilt the machine back and see the coupler between the motor and transmission from underneath. I can walk you through replacing it if you want, but I wouldn't recommend it if it is still under warranty. There could possibly be something more major wrong that has caused it to break and some of the factory servicers are real picky about customers working on a machine under warranty. If you need it running tonight, he may be in trouble.
Post back if you need further help or have more questions.
Posted on Oct 21, 2007
  • 3 Answers
SOURCE: Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Posted on Mar 01, 2009
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
May 22, 2010 | Kenmore Washing Machines
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Getting code LF won't wash stays on same amount of time
Try unplugging the washer for 10 min. This will reboot the circuit board. Sometime you can get small power surges from the electric company and these will confuse the electronics in the curcuit board. Unplugging and resetting the system wil sometimes work.
Apr 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have the Kenmore elite calypso washer and it stops and displays LD. What does this maean and how do i fix it? Thanks!
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 24, 2009 | Kenmore 2295x Top Load Washer
WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Jan 16, 2009 | General Electric WCVH6800J Front Load...
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Stuck at 7 mins left
sounds like you have a bad timer or check your belts
Nov 02, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washer make clicking sound
First locate were the sound is coming from. put your ear very close to the timer and listen for this clicking sound. remember a timer will make a clicking noise which makes the timer go around. Timers can get noisey with age. The sound might be coming from below also .I would run your washing machine until the part fails. They might also have a motor controller in this unit which is seperate to the timer which will make a high pitch clicking noise.
Aug 18, 2007 | GE WHRE5260E Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
81 people viewed this question
Dan Webster
Dan Webster
Sal De
