Question about Asko T721 Electric Dryer
ASKO T721 dryer - Squeaking
Our dryer begins squeaking as soon at is heats up. We REALLY dont want to call a repairman for only a noise problem. Any suggestions woudl be appreciated.
  • Anonymous Mar 17, 2008
    when i first turn on the dryer, it squeaks for about 30 seconds then stops, this is a maytag dryer that is about twenty years old.
  • wmjohnston Oct 22, 2008
    We have the same problem. Particularly aggravating because we live in a small condo - no escape from the squeaking!
    Sergeant:
  • 351 Answers
The dryer needs a service you need to replace the front rollers,jockey pulley and grease the jockey pin,check or replace the belt.remove the lint build up from the front frame and element assy.also check that the felt and rubber seal arond the front frame hasnt come out.you can replace it but its hard to get in and you may have to replace the front frame.i find its any easy repair but i see a lot of asko dryers (not because there bad they just need a service about every 5-7 years).hope this helps.
Posted on Mar 20, 2008
6ya staff
SOURCE:
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
The dryer is making a very load knocking noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 03, 2011 | Asko T721 Electric Dryer
Dryer runs and heats but has squeaking noise. Drum seems to labor mid cycle and then shuts off. If I turn cycle to off and wait unit will resed and begin cycle again with normal heat. Squeaks in on off...
Hello & Welcome to FixYa
The squeaking sound comes when the belt is either broken or worn out and needs replacement or the idler pulley is bad. If you want to do this yourself then you can check this video on YouTube:
Please get back to me if you have any other questions.
Kevin
Jan 30, 2011 | Kenmore 73932 Gas Dryer
Our dryer was making a loud squeaking noise for a while now it is tripping the circuit breaker as soon as it is started what do you think is our problem.
The drum rides on a bearing in the rear which cause the squeal. The squeal eventually cuts into the bearing and the whole drum begins to rub against the heating element. This causes the breaker to trip.
How it works: GE clothes dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 05, 2011 | GE Dryers
My Asko stacking dryer makes a small squeaking noise
Hi, Check for the following:
  • Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time
  • Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
  • Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
  • Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Apr 17, 2010 | Asko T761 Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Dryer squeaking & Clunking noise
Your particular unit has quite a few things that could be making a real loud noise.....The idler pulley, blower wheel, rear drum rollers, front drum glides. Bottomline is you have to get in there and take the unit apart..vacuuming while there and if the unit is making such a noise, it will be obvious where the problem is.....If I can help further, I am here.......
Eric Campion
Mar 04, 2009 | Dryers
Dryer stops heating and we hear squeaking noise
They could cause the noise. Call a repairman, because whenever you are dealing with gas, there brings a whole host of other issues to the forefront.
Jan 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
May 03, 2008 | LG DLE2532W Electric Dryer
Asko T721 Electric Dryer Logo
562 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Mat Kramer
Mat Kramer
Level 1 Expert
Ekse
Are you an Asko Dryer Expert? Answer questions, earn points and help others
