I have to reset my channels on my sendai car stereo every time i turn engine off
  • 4,234 Answers
I would suspect that the radio is not installed correctly. There should be 12V present on one wire for retaining memory. There is a capacitor inside the radio that will retain memory for a short time (less than 5 minutes), but you should not have to reset the system after each start. If the wiring is correct, then the internal memory system may be defective and require replacement.
Dan
Posted on Mar 17, 2008
6ya staff
SOURCE:
So I went to replace the stereo on my 2002 Buick rendezvous and so I sniped a few wires off the stereos, then behind the dash there was a buzzing sound, and then I went to start the car but no luck. I...
No code reset will not allow restart. procedure takes half an hpur with out tech2 scanner. you have to put key in turn it to crank and then leave it in on position for ten minutes turn the key of and repeat two more times.
Nov 15, 2013 | Cars & Trucks
I need an instruction manual for a sendai cd789 car audio system
Hello
Get into this link. You can download the user manual to your car audio from here. If you feel any difficulty in downloading the same, inform me with your email address by Fixya comment box. I've the downloaded manual with me, and I'll send a copy of it to you by return mail. OK.
www.halfords.com/.../Sendai%20CD789%20Manual... - United Kingdom
Please do not forget to rate this solution. OK.
Dec 22, 2011 | Audio Players & Recorders
How to reset oil % life on stereo info
sometimes it will reset by turning the key on, (engine not running,) you can floor the gas pedal 3 times and it will reset. turn key on and floor it 3 times in 5 seconds
Sep 05, 2010 | 2007 Pontiac G6 GT Convertible
Sendai CD789 radio preset stations
At the back you should have a red, black and yellow (maybe blue). swap the red and yellow over. Yellow = memory [constant voltage] red = live with ignition. Hope this helps. Wayne. Tech Rehab. http://techrehab.t35.com
Apr 20, 2010 | Car Audio & Video
Amplifier doesnt cut off with car, battery dies every time
I assume you are speaking of the car battery, and it gets drained when the ignition is turned off.
Your problem is you have connected your system to the wrong power connection. Automobiles have wiring lines that supply power all the time, to other parts of your vehicle. You need to find a power connection, preferably from your fuse box, that stops supplying power when the ignition is turned off. This will also help provide a back-up fuse incase of any other problems you might incur.
Sep 09, 2009 | Dual TOA IP-600D Channel, 400W Power...
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Kenwood KDC-W312S wont keep the saved channels after car restart
Check the yellow wire connection on your wiring harness... This is the wire that provides continuous power even when the ignition is off. This is how the radio remembers presets/time and such. Every time you turn off the car, the radio "resets" because you dont have the yellow wire connected to an ALWAYS HOT wire.
If you cannot find a hot wire, then you can run a wire from the yellow on the back of your radio directly to the positive terminal on your battery. Dont worry, it doesnt draw enough power to run your battery down.
Most cars have a cigarette lighter or power port somewhere that is always hot. You could always run the yellow wire off of one of these.
Just find a way to get the yellow wire on a hot wire and your stereo will remember the presets.
Mar 29, 2009 | Kenwood M-303USB Shelf System
Stereo channel
Hi again,
I was just checking other related questions when I saw your post. I am afraid that each would have to use separate inputs. Please check your original posting for added information.
Hope this be of additional help/idea. Pls post back how things turned upor should you need additional information. Good luck and kind regards.Thank you for using FixYa.
Nov 16, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Akai lct2785ta Sound Problem
Bear with me...I will start talking about CC, but I think my solution may work for you, too. I noticed that every time I turned on Closed Captioning, when I changed channel, it went off.
I went into the on-screen set-up, and turned on the CC there. Now, when I turn OFF CC, then change channels, it comes back on.
So, it may just have to do with your set up. Go there and set the default sound to stereo and see if that fixes it.
Good luck.
Oct 05, 2007 | Protron PLTV-37 37 in. LCD Television
270 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
