Question about Brother MFC-8460N Laser Printer
Drum is near end
My printer shows that I have the drum near end . I changed the cartridge and the toner and still the message is still there with a very poor quality of the printed document where it shows a whole strip of black line over the whole page. Please advice
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
This has nothing to do with packaging still on the drum...
it means the drum needs to be reset. download a users guide or service manual for the printer from the brother support page for this printer. i recommend a service manual as it will tell you everything you could possibly want to know about the printer down to disassembly and repair. including how to reset a drum after replacing it.
Posted on Jan 13, 2018
Some packaging is still on drum probally.
check that out and to clear message u need to open all the front covers then hit the clear/back button and then hit number 1 and your set
Posted on Apr 09, 2008
SOURCE:
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
How do I take off the message drum near end when its has been replace
Open the toner cartridge door. Press clear on the console. A message shold display saying "replace drum? press 1 or 2" press the corresponding number to reset the drum counter. This is a very important step when replacing the drum as it actually changes the voltage setting for the dc power regulator. If not performed, and a partially used toner cartridge is in, waste toner can be pulled out of the cartridge and can contaminate the drum unit.
Sep 30, 2010 | Brother MFC-8860DN All-In-One Laser...
Drum End Soon
You will soon need to replace the drum. Its considered a consumable just like the toner cartridges. You can purchase the drum anywhere that sells brother pruducts.
May 24, 2010 | Brother HL4040CN Laser Printer
Drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Apr 19, 2010 | Brother MFC-8860DN Printer
I have a brothers copier DCP 8060 and it has a message in the lcd window stating drum near end. What is this...is this is different than the toner cartridge?
The drum unit will wear out and need replacing. The toner cartridge clips into the Drum Unit.
If you print out the system setting report, it usually shows a bar graph with drum life indicated as a percentage.
Dec 08, 2009 | Brother Office Equipment & Supplies
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
"drum near end". What is this? is it easy to fix? how do you fix?
There are two main parts in a laser printer: the toner cartridge and the image drum. Most people are familiar with the toner cartridge, but sometimes the drum is an unknown until you start seeing error messages or streaks and blotches begin appearing on the output.
In some printers, the drum is replaced along with the toner cartridge. But yours has a separate drum, and the printer is warning you it's nearing the end of its life. Replacements are available from a number of sources online, as well as at big-box office supply stores. Genuine Brother drum units will cost over $100, and after-market brands usually range from $50 to $75.
A typical vendor and price is here (I've never purchased from this place myself, and have just used it as an example):
http://www.quikshiptoner.com/catalog/brother-dcp-8060-drum-toner.html
Please take a moment to rate this solution if you've found it helpful, and thanks for asking here!
Mar 04, 2009 | Brother DCP-8060 All-In-One Laser Printer
Brother MFC-8460N Laser Printer Logo
681 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
