Acer Aspire 1690 keeps freezing
My Acer Aspire 1690 keeps freezing up; no blue screen, everything just stops and no errors logged in event viewer. Any ideas?
    Sergeant:
  • 349 Answers
Try booting up in safe mode (F8 when booting) if it works ok then it is must likely a driver conflict, remove what ever it was you last installed.
you may have a bad ram stick, run memory checking software such as Memcheck,you can download it from the net,
microsoft also has one go to http://oca.microsoft.com/en/windiag.asp
to download it
please rate my suggestions if they are worthy
good luck
Terry
Posted on Mar 18, 2008
I have acer aspire when i turn it on only blue screen come on how can i fix it
Hi !
Blue screen means that your Hard Disk drive is damaged or dead and it cannot be repaired. Solution is to replace new the hard disk.
Good Luck and thank you for using FixYa !
Jan 06, 2011 | Acer Aspire One PC Notebook
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors
The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors
However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
Update Windows - missing updates, including service packs can be a source of stop errors.
Check your system - run a virus scan and spyware scan after updating your definition files.
Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
Acer Veriton M265 and M275 Desktops shutoff video without any apparent reason. CPU continues to run, CPU temp ok, no scheduled tasks, no screensaver, no power options, no hibernation, nothing logged into...
If there are no error logs, seems to be a hardware problem.
Could be the monitor or the video card.
Try updating the video drivers and BIOS from the Acer website.
Nov 16, 2010 | Acer Veriton M265 Minitower Desktop 160GB...
I cannot load windows it gives me the blue screen than dumps the memory
There are many possible causes for blue screen errors. Faulty memory, device drivers, viruses. Try to analyze the blue screen error by looking at the error code and the event log, so you can find the right solution.
Here are some ideas: http://www.pcauthorities.com/pc-errors/how-to-repair-blue-screen-errors
Jun 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
Display Adapter error (ati3duag.dll) after installing Windows 7
The following link tells you all about blue screens. Please read it carefully and do what applies in your case.
http://supportapj.dell.com/support/topics/global.aspx/support/dsn/en/document?docid=356576
May 12, 2010 | Acer Aspire 1690 Notebook
Acer Aspire boots from hd or cd to black screen with mouse in center. No windows logo just the Microsoft Corporation copyright. Can this be fixed?
go to BIOS change the primary boot up from HDD to dvd.cd rom . it willl automatically boot from dvd/cd and then preoceed installing/repairing windows
Jan 13, 2010 | Acer Aspire 5315 Notebook
My leptop acer 4720zg physical dumping error
1) Examine the “System” and “Application” logs in Event Viewer for other recent errors that might give further clues. To do this, launch > Eventvwr.msc from a Run box; or open “Administrative Tools” in the Control Panel then launch Event Viewer.
2) If you’ve recently added new hardware, remove it and retest.
3) Run hardware diagnostics supplied by the manufacturer.
4) Make sure device drivers and system BIOS are up-to-date.
5) However, if you’ve installed new drivers just before the problem appeared, try rolling them back to the older ones.
6) Open the box and make sure all hardware is correctly installed, well seated, and solidly connected.
7)Confirm that all of your hardware is on the Hardware Compatibility List.
8)Check for viruses.
9)Investigate recently added software.
10)Examine (and try disabling) BIOS memory options such as caching or shadowing.
Jan 03, 2010 | Acer Aspire 4720 Notebook
Acer Aspire 4720z WIndows Vista- crashes every day
there is a programme on the pc that is not compatable with vista, this is called "hanging" this is a common problem with vista as it is not compatable with certain programmes and hardware, you need to find the software that is causing the hang, go to the event viewer by right clicking on "my computer" and select "manage" select event viewer and the software, that will tell you which programme is causing the hang/freeze and uninstall it
Nov 16, 2008 | Acer Aspire 4720 Notebook
My HP Pavillion desktop had given me a "serious error" screen and then a "blue screen" and stopped working. It would not reboot. I had to use my recovery disc to get it to boot up. It...
you need to make a note of that blue screen you say you get when the computer stops working.. those are know as the infamous blue screen of death (no kidding) or as ms call it stop error screens..
make a note of the stop error code you get on the screen.. it's way to fast for you to see it.. you may be able to see what the stop error code is by going into the event viewer (as long as you have checked to have this events reported to event viewer in system properties> advance tab and start up and recovery area.).. look inthe event viewer (start>right click my computer>manage>event viewer) and look for system events.. you should see a white x inside a a red circle.. look for those error events and look for the error code.. it should give you something like 0x????????? post that error here.. or google it, it may give you an idea of what may be wrong. at this stage it could be software related or hardware related?
did you install a device recently? the driver is very comun problem that may give you a bsod if it's critical.
Sep 21, 2008 | HP Computers & Internet
Computers & Internet Logo
153 people viewed this question
Alun Cox
David Payne
David Payne
