Question about Sony Cyber-shot DSC-W55 Digital Camera
Unable to take pictures
Have had the camera since September last year has worked fine upto now. But now when I thurn the power on the lens goes in an out 3 times if beeps for about 5 seconds and then displays a message reading 'Turn the power off and on again'. If I do this the same sequence happens again. is there any solution to this?
  • 3 more comments
  • gymnastkat Mar 19, 2008
    Same problem...I've also had no problems until now - ON VACATION!
  • Ashley Harris Mar 26, 2008
    I've had mine since November, and I have the exact same problem, except for it doesn't beep before it displays the message.
  • fotomusa Apr 01, 2008
    it's exactly the same problem and i was begining to thing my brother had done something with the cam
    it comes on and off 3 times, and you still can't use the view finder or get a response from pressing the shutter button.
    this ruined my friend's wedding
  • Anonymous Apr 06, 2008
    Mine does the same thing only it doesnt beep.
    I have only had it since Xmas '07.
  • jiggadk Apr 07, 2008
    mine started doing the same thing after having it for only 3 months!! and now its to late to return it!!!! the bottom light next to the viewfinder thing blinks orange. i have read that that light has to do with the charge and the battery. i am going to try replacing the battery and hopeflly that will fix it.
  • 3 Answers
I had the same problem, I returned it to where I bought it and they replaced the camera with a new one, however it was only 5 weeks old when this happened.
Posted on Mar 21, 2008
Power on screen white
lens assembly (barrel unit) struck up. slightly push lens while power off & pull the lens while power on. repeat this 2 to 3 times it will works. dont apply any oil in the barrel unit. but you may use body spray or room spray to solve this issue permanently
Feb 06, 2010 | Samsung Digimax A503 Digital Camera
I have a 5 yr. old Canon Power shot SI camera. It
Hi Mike, the bad news is that your camera is beyond any hope of economic repair.Your camera displays the absolute textbook symptoms of this fault.
It has suffered a ccd failure, these often occur on cameras which are five to six years old and replacement costs far more than the camera is worth (that's if you can get the spare part, and it's not a DIY job).
Your camera has the infamous Sony 5MP ccd fitted; huge numbers of these failed prematurely due to a manufacturing defect and there was a quiet recall program whereby affected cameras were repaired for free (but only if the customer complained), usually by Sony. Apart from a couple of Sony and Nikon models this process ended last September as by then almost all affected models had pased their design life expectancy. Failures after that are therefore no longer considered to be premature.
The problem which causes ccd's to fail is now well understood and manufacturing processes were improved by all manufacturers, but you still shouldn't expect ANY digital camera to last more than five years without failing for one reason or another. Even top of the line professional Nikon models only come with a measly two year warranty: I can buy a new car for that with a seven year warranty and the car has far more which can go wrong... Sadly, late model highly electronic AF 35mm film and all digital cameras just won't last as long as simpler models.
Sorry there's no prospect of a fix, but I hope that you found my reply to be of some use. If so, please rate my answer.
Feb 04, 2010 | Canon Power-shot S1 IS Lens Converter
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
E 18 problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 27, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Pictures come out blurry
change your settings, set the image size to a higher number. and select "best" on picture quality
Nov 24, 2008 | Cameras
Auto focus quit working.....Help !!
google its user manual
changing lens from stock might be the issue
or 8 years auto focus sensor may be stuffed
Apr 11, 2017 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Lens not working after only one year
Same here.. bought the camera early April '07. Problem began in May of '08. Turn it on and the lens goes in and out several times but it won't focus.
Jul 12, 2008 | Olympus FE-230 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
