Question about Kenmore 24902 Top Load Washer
Kenmore 80 series
Went through wash cycle completely
When it came time to spin a clicking sound just continues
Sounds like a gear mssing
Housing is contained
Thanks
Mike
  • Help pllease Mar 30, 2008
    My kenmore 80 series completes the wash cycle but stops and starts a clicking sound then nothing. It doesn't empty the water or spin.
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like you migh have a bad motor coupling 285753a, this machines equivelint to a belt, motor turning but transmission not??? doesit agitate or just make same horrible noise??? well if so heres how to replace it. looks and reads a lot longer then it actually takes. should be done in under 20 min.
remove 2 screws holding down console, depending on year they are either on the bottom of the face of console in both corners or looking over the top of unit you'll see 2 screw head in both corners screwing down into machine. remove the screws and the console will flip backwards. disconnect the harness going through he main top(lid switch assy). and twist off with a screwdriver the 2 brass wavy clips 3 inches in from either side of machine.( you nay have to twist hard but they will pop theyre sorta spring loaded), lift of the entire cabinet and set side. youll see the pump assy 2 spring clips remove it(leave the hoses attached just hold out of the way, next 2 spring clamps hold the motor and youll find the coupling just behind there, youll need to smack the coupling back on to the shaft, i use the back end of my nut driver and hit with small hammer. dont need to kill it but will need to be forced on, and your done reassemble, (dnot forget ot plug back in the lid switch before closing the console,) ant the cabinet hooks under the front of machine and should fall right back into place, the brass clips will line up real good when cabinet is on properly just a firm push down and they snap right back in
Posted on Mar 18, 2008
Loud banging noise during spin cycle
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
Jan 31, 2018 | Washing Machines
Kenmore 80 series washer will not spin by hand
Sound like the transmission may be broken.
Jun 28, 2013 | Washing Machines
My kenmore series 80 washing machine makes a clicking sound during the spin cycle.
Might be something lodged in the drain pipe on the drum, such as a coin or similar object.
Dec 20, 2011 | Kenmore Washing Machines
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Series 80: Loud clicking at spin cycle
sounds like spin tube bad will need to remove basket and gearcase to remove it
Sep 30, 2008 | Kenmore 20172 Top Load Washer
Washer dead
ck to see if you here a lid switch click when lid is slowly closed if not suspect lid switch may be on right sidew of opening or under left rear of lid at hinge also ck for loose lid hinge screws left side first
Sep 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 23012, spin cycle problem
This sounds like a broken coupler gear. I'm having the same problem with my Kenmore-80 Series. The machine fill up, pump out, but when I try to spin I get nothing and the I can hear the motor humming/grinding. I've heard the coupler gear is not expensive $35 or so and the repair procedure is not difficult, but I can't locate how to fix it. If you find any additional information, please send my way. I don't want to pay $150 or so to have it serviced.
Mar 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer not spinning
you need the gear box not the timer.
Dec 20, 2007 | Washing Machines
Kenmore 24902 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
