Question about Splendide 2000S Vented Washer/Dryer
Low water Our Splendide 2000 S does not fill with enough water. Is there an adjustment for water level?
  • 1 more comment
  • Burman Mar 17, 2008
    where should the level be on the door?
    where do I find this tube?
    where is the air tube?
  • 796 Answers
Have you checked the outlet valve..
is it clean??
Posted on Mar 17, 2008
  • isaac johny
    isaac johny Mar 17, 2008
    make sure the tub is empty of water and clothes, then blow through that
    tube to clear it, then re-attach it to the water level switch, then try
    to fill the machine.
  • isaac johny
    a water pressure switch or something blocking the air tube going to the switch.
    Guru:
  • 1,894 Answers
Water level is not detected means there is the problem wiht the sensor
  • 3 more comments
  • dewan nafees ahmed Mar 17, 2008
    Water Is Entering Washer But Tub Does Not Fill
    • Standpipe for the drain hose is not the correct height.
    (Fig. 2), drain hose is to far into standpipe or air break
    does not exist.
    that is what your manual says.
    for manual see in page 16
    manual link
    thank you sir
    sir please see you manual FIG 2 and see the page number 16
    you are fixed.
  • dewan nafees ahmed Mar 18, 2008
    please go by manual
Have a new 400A and water level is normal in the tank : upon flushing the bowl fills almost to an overflow?
What's wrong with that that's were it should be.with a 2.5 gal tank that water level is corect.Iff think that's too much, adjust the water level adjust clip, by sueezing clip and move it down to adjust the water levelto lower.
Sep 10, 2014 | Fluidmaster 400A Toilet Fill Valve Cap
Water level adjustment
If it has a ballcock bend the ball upwards till you have a high enough water level
Nov 26, 2013 | Toto Home
The toilet does not refill the tank to the water level line, as a result the float is about 20mm below the water line and the toilet is hissing 24/7. How do i adjust to make the toilet fill the tank to the...
The fill valve sounds if it is bad.Go to lowe's and get a fluidmaster fill valve(about $8) instructions included.turn off water and remove water from tank then disconnect supply tube,remove old fill valve install new,follow installation diagram,and the adjustment process to adjust the water level to correct level that should take care of your problem.
Jun 19, 2011 | Caroma toilet - water saving Sydney Low...
How do you adjust float level on toilet? The water closet only fills to 2/3 level and I want it higher because its not emmitting enough water to properly flush. Thx.
Go to mftr web site to get a break down of fill valve it should show how to adjust water level,or contact co.and ask for tech support they should be able to tell you how to adjust water level or e-mail you a instructional diagram of how to adjust.
Jun 17, 2011 | Toto Drake 2pc. E/F Toilet CST744S-01
I had an American Standard Cadet3 Right Height Elongated toilet installed. After flushing, water level in the bowl drops to a very low level. Enough remains to prevent gasses or orders, but just enough. I...
Adjust the water setting of the tank to higher level, meaning an additional water will be added to the tank. The purpose of this is to release extra water that will fill the missing water level in the bowl.
Nov 10, 2010 | American Standard 2002.800.021 Champion...
Splendide 2000 Model Help Needed
I have the same problem with my WD802 "pre M". I have found this forum and it as helped me some. Here is one forum that might help you - http://applianceguru.com/forum2/17215.html - I think it's my control module, but I cannot find a test guide for my "pre M" WD802 module. I am Calling Splendide first thing tuesday to see if they have a tech manual for the "Pre M" models. Good luck with your WD802.
Jun 29, 2010 | Splendide 2000S Front Load Washer / Dryer
Lg intello WD1243FH low water level? My Lg will not fill with water properly. It only lets in enough water to get the clothes wet then stops filling. I tried filling it manually through the drawer but as...
Try adjusting the water lvl going into the washer. Adjust accordingly. If you have a meter, just the resistance of the valves. Unplug of course. It should read about 1.4k ohms ish. Could be higher or lower but roughly that.
Apr 28, 2010 | LG Washing Machines
LOW WATER LEVEL
you cant the water is meter though a pressure switch,,,but heres a trick but you have to find your way from here,,,fill the tub first than push the clothe,,careful of overflow,,if you do it enough you will be a master,,,
Jan 06, 2009 | Frigidaire GLWS1439F Top Load Washer
Splendide 2000S Vented Washer/Dryer Logo
160 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ronny Bennett Sr.
Ronny Bennett Sr.
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
