Water dispenser lever is broke, is this something that I can fix myself or is it better left to a repairman
On my FRIGIDAIRE MODEL: PLHS69EGSS side by side
1st, unplug or turn breaker off for refrig. 2nd, remove the slide out drip tray, 3rd, remove the 3 bottom screws at the bottom of the dispenser bezel (behind the drip tray). 4th, remove the bezel (slide up about 1/4" and pull forward, gently), WHEN DOING THIS BE VERY CAREFUL YOU DON'T ACCIDENTLY UNPLUG THE CONTROL BOARD FROM THE MAIN BOARD. 5th, remove the 3 screws holding the dispenser mechanism in place. 6th, remove the water dispensing hose from the dispensing mechanism., 7th, carefully unplug the power supply to the main board. hold down the clip to do this. 8th, with the dispenser out, remove the water dispenser lever plug from the coil board, 9th, remove the 2 screws for the metal hold downs for the lever pivot.
Be SURE YOU LOOK AT HOW THE SPRING IS LOADED. OTHERWISE THE LEVER WILL NOT FUNCTION PROPERLY.
chances are, you will have difficulty removing the water hose from the dispenser unit. I did. I also had a harder time trying to get it back in. The factory hose is pretty rigid and I figured there mus be a better way. I had some 1/4" clear hose from home depot. I got a piece of 1/4' tubing and made a splice from the factory tubing to the clear, flexible tubing. The flexible tubing allows you to have additional tubing to play with and makes the job much, much easier. good luck
For your own good go to a good/wellknown repairman
