Have harmony remote. Tv not receiving video signal.
    President:
  • 4,402 Answers
Remote codes
http://www.remotecentral.com/index.html
Posted on Mar 17, 2008
NEED AN IR REMOTE OR AN ALTERNATIVE REMOTE AND INSTRUCTIONS
Go to TV Parts Universal TV Stands DLP Chips ShopJimmy to see if they have a replacement remote. If not then get a logitek Harmony remote control. It will operate every component you have that needs a remote. It will never go obsolete or not have the right codes either. It gets it's programming from their website.
Feb 21, 2016 | Sony Str-de805g Audio Video Control Center...
Sharp lc-46x8e
Try getting that button to work by either cleaning out the contacts or inserting a small piece of aluminum foil in the contact area. If you get it to work you can program the harmony with its signal.
Sep 15, 2017 | Logitech Harmony 688 LCD Remote Control
My lg lcd tv says it has no signal although my directv receiver and surrond sound comes on
It sounds like you just have the wrong input for your tv, Go to logitech;s web-site and reprogram your remote control is your other option.
Jul 04, 2012 | Logitech Harmony 550 Remote Control
Looking for vizio tv remote codes for denon 1802
I don't think you'll find any codes as the Vizio remote uses a newer IR coding than the Denon.
However, you can replace both remotes with a Logitech Harmony Universal Remote!
The Harmony remotes work on several different IR coding schemes with many different types of devices.
If 1 remote is what you're after, the Harmony remotes are the best!
Mine has saved several devices for me because I could just download the latest IR codes from their website AND I can teach it the codes if I can't download them but still have the original remote for the device.
This is definitely the way to go, IMHO.
Hope this answers your question.
Dec 04, 2010 | Denon AVR-1802 Receiver
Compatible TVs
I can help you with your Logitech Harmony 550 remote control.
The Logitech Harmony 550 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 550 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Harmony MAC Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Jun 06, 2009 | Logitech Harmony 550 Remote Advanced...
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
Infrared signal connects to tv etc but then dies
If the infared reciever on the reciever is that bad you might consider getting a Infared repeater (look on ebay, they are like $50. they work pretty well
Feb 06, 2009 | Kenwood VR-309
Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
Oct 30, 2008 | Logitech Harmony 880 LCD Remote Control
Logitech Harmony 670 universal remote
Greetings Hendon,
The close captioning your looking for would have more to do your television or video source then your remote control.
Depending on how you receive your broadcasting you may want to make basic adjustments to your other equipment. If you receive it through your television you should check your television setup menu for something along the lines of "caption", "CC", or "Text". As well if you receive broadcasting through a cable or satellite box their setup menus should have options for similar options.
I hope this helps.
Jon
Go Ahead. Use Us.
Jun 01, 2008 | Logitech Harmony 670 LCD Remote Control
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Televison & Video Logo
Top Televison & Video Experts
